EGR Spacer coolant line connections
Old 09-02-2014, 05:00 PM
Raphs50
Raphs50's Avatar
Question EGR Spacer coolant line connections
I think I found the answer to this question in another thread, but if anyone can confirm I would appreciate it.
My 86 GT has had the Cobra intake on it since I have owned it, which does not have the coolant lines running to it, since there is no EGR spacer on the Cobra intake. It is all one piece. I am moving to a new intake (the Professional Products knock-off of the Edelbrock Performer), which will require the EGR spacer (I'm in Cali and have to pass SMOG).
From what I have read, the coolant lines run from one of the rear ports on the lower intake, to the back of the EGR spacer, then from the front of the ERG spacer to the heater supply/return tube. My heater tube has a small connecting tube that sticks straight up from it, which appears to have been plugged when the Cobra intake was installed. My plan is to unplug that connection and connect some new hoses as described above. Since the shop manual does not seem to cover those connections, I was hoping someone could confirm that this is in fact the correct way to connect the EGR spacer coolant lines.
Thanks in advance for your help.
Raphs50 is offline
Old 09-03-2014, 09:05 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Yep. One hooks into that coolant pipe and the other hits the lower intake port on the RR.
Boss_Hotrod is offline
Old 09-03-2014, 07:38 PM
Raphs50
Raphs50's Avatar
Great, thanks. Seems odd that coolant needs to run through the EGR spacer, but I guess the Ford engineers know what they are doing.
Raphs50 is offline
Old 09-03-2014, 08:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it's not odd, it aids in cooling the combustion gases.....but since I'm anti-smog, I run no emissions crap
mjr46 is offline
Old 09-04-2014, 02:21 PM
Raphs50
Raphs50's Avatar
So, I guess actually you are pro-smog, not anti-smog.
Unfortunately, being in CA, if you want to still drive on the street, I have to stay emissions legal. I would love to eliminate all of my emissions stuff, but still want to be able to license the car for the road.
I certainly makes sense to try and cool the air before entering the intake manifold, it just doesn't seem like it would really do much to help that. I guess 180-200 degree coolant is colder than a hot intake manifold.
Appreciate the help.
Raphs50 is offline
Old 09-04-2014, 04:48 PM
Stanger444
Stanger444's Avatar
Saw this right before I was going to make a thread. Please someone help! I have a stock 1990 5.0 GT, I had to replace the gasket from my throttle body to the egr/spacer. The old gasket was caked on there so badly I used a small pneumatic grinder to get it off. In doing so I must've scratched the surfaces on both the Throttle body and the egr. I started it up and coolant leaked everywhere! Started to get drawn in through the intake and engine started to bog and almost died before i turned it off. My questions are
How do I bypass the coolant lines? I dont want any coolant at all going through so it can leak and get drawn into my engine. Do I just take those two black hoses running into the egr and 1.) Put them together somehow, or 2.) Cap them off somehow?
Secondly, reading up on this issue many people argue about what the purpose is. Assuming it is to cool the exhaust gases, people said there will be a problem of the egr getting hot and my main CONCERN, the engine pinging or detonating and stuff. How do I avoid this? Delete the egr somehow? Just plug up the lines to it? Please someone help I am desperate!!!
Stanger444 is offline
Old 09-04-2014, 05:01 PM
dawson1112
dawson1112's Avatar
If you have the egr hooked up keep the coolant lines , and use a generous helping of RTV sealer on the surfaces .
dawson1112 is offline
Old 09-04-2014, 05:05 PM
Stanger444
Stanger444's Avatar
Idk I don't believe in myself for that to work to well, deleting/bypassing seems simple enough, I just want to know the few specifics of exactly what to do.
Old 09-04-2014, 08:44 PM
65Raven65
65Raven65's Avatar
If you decide to delete it, I recommend the the Accufab throttle body and EGR delete spacer.
I got this for my '87, I needed a throttle body anyway, and the car was running like crap due to faulty EGR components so I went the delete route. I don't have to worry about emissions in Texas so spending the money fixing all of the EGR stuff versus deleting it was a no brainer. I don't know about your situation and your state laws. Also, with a 1990 model, you'll either have to buy a jumper that tricks the computer, or you'll have to live with your check engine light on all the time. They sell them on Ebay from time to time, or you can make your own, I've seen the plans on the innerwebs.
Here's the parts I got, I think you can just buy the spacer if your throttle body is OK:
http://www.latemodelrestoration.com/...-Throttle-Body
Good luck!
65Raven65 is offline
Old 09-05-2014, 10:50 AM
Boss_Hotrod
If you unplug the vac line from the valve the pcm will delete the function and not set a visible CEL. Then you can bypass the spacer with no issues. You still have egr gases going up to the spacer but you wont have any drivability issues.
Quick Reply: EGR Spacer coolant line connections
