Advice
Old 09-06-2014, 02:27 PM
Doctocc
Doctocc's Avatar
Default Advice
Can anyone recommend a good OBD I code reader and a timing light that won't break the bank? I checked out Amazon And the choices seem to have poor durability.
Doctocc is offline
Old 09-06-2014, 07:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
a paper clip for obd 1 is all you need
mjr46 is offline
Old 09-07-2014, 05:37 PM
Js88lx
Js88lx's Avatar
+1.. obd1 reader is a waist of money!
Js88lx is offline
Old 09-08-2014, 09:00 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum.
As stated above, a paper clip is all you need, well, and a pen and paper to keep track of codes.
There are step by step write ups on how to pull codes on a Mustang in this forum. Or just Google it, or YouTube will have a video. Only takes 5 min. the first time. Very simple
88 orangepeel notch is offline
Old 09-08-2014, 09:58 AM
leftyatm
leftyatm's Avatar
Sorry what does a paper clip do? Nothing just like the scanner or do you use it to reset? Thanks
leftyatm is offline
Old 09-08-2014, 10:08 AM
88 orangepeel notch
You use it as a jumper wire in the OBD I plug that's under the hood. Then count CEL flashes, those add up to go give you the code. Example ...... 3 flashes then a pause, then 5 flashes = code 35.
Omgitsa88Stang
10-05-2015 07:33 AM
Shadow7874
09-24-2015 09:06 PM
2k232
09-16-2015 10:28 AM
EASTIDEE123
09-15-2015 11:08 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Advice
