Needing advice on building the 5.0
Old 01-21-2015, 02:01 PM
1stMustang86
1stMustang86's Avatar
Default Needing advice on building the 5.0
This is my first Mustang and I want to build it to about 500hp. I'm not sure about the best route to take, any advice or help would be greatly appreciated.
1stMustang86 is offline
Old 01-21-2015, 06:08 PM
barnett468
barnett468's Avatar
lots of options like start with a 351 and stroke it, 302 stroked to 347, superchargers, twin screw blowers, afr or trick flow heads etc..
barnett468 is offline
Old 01-21-2015, 06:21 PM
1stMustang86
What are the hp gains of stroking it to a 347
Old 01-21-2015, 06:43 PM
DeepImpactPony
DeepImpactPony's Avatar
Before you ask this question, you first have to ask yourself, what is your budget. Your budget will best be able to tell if your horsepower goals are attainable. Keep in mind, you will also have to spend on chassis fixes such as torque boxes, and subframe connectors, and some suspension mods as well, to put power to the ground.
DeepImpactPony is offline
Old 01-21-2015, 06:48 PM
barnett468
barnett468's Avatar
well, i don't know what ypur current hp is so i don't know what the "gain" would be over your current set up . . also, different dynos give different readings, but on most engine dynos, you can get 400 hp at the crank out of a carbureted or efi 347 with no power adders and still have it idle, kinda sota.
also, a 347 will have a shorter life span than a 302.
Old 01-21-2015, 07:38 PM
uedlose
uedlose's Avatar
Budget? intended use of the car? N/A or power adder? 500 HP at the wheels or crank? Why 500 HP?
uedlose is offline
Old 01-21-2015, 07:49 PM
bluebeastsrt
bluebeastsrt's Avatar
Not really going to get to 500HP with a 302 without a power adder. Going fast is expensive.
bluebeastsrt is offline
Old 01-21-2015, 08:27 PM
1stMustang86
I have plans for a turbo setup and hoping to stay around $10K. I will be doing most of the work myself. As far as the 500hp it seems a lot more practical to reach with my budget. I'm using it for street/strip and it's not going to be my daily driver. But will get driven on the streets.
Old 01-21-2015, 09:34 PM
reldla1996
reldla1996's Avatar
Recommend either a 351 block or an aftermarket 302 block (preferably big bore and stroked) at those power levels with a turbo. Decent heads, intake, and headers will make 500hp relatively easy with a turbo.
reldla1996 is offline
Old 01-22-2015, 06:57 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
347's don't have any shorter life span than a 302. period (how any motor is used dictates life span)...........I have 2 customers with 100k on theirs, one uses it as a courier service in a 94gt, and both don't burn any oil.........do the machine work right and it'll last, going on 7 years with mine and had many bottles of no2 through it and doesn't burn a drop either.....pulled it apart 2 years ago to inspect it...and looked like the day it rolled off the assembly line......and to those who argue worse rod rationale.......many sbc's that have a far greater/worse rod rationale than a sbf 347 and have lived well past 100k, OP if you want 500 hp and for it to be relaible at that hp range do as reldl1996 states
mjr46 is offline
Quick Reply: Needing advice on building the 5.0
