Stupid fuel pressure regulator question
Old 02-24-2015, 12:38 PM
bluebeastsrt
bluebeastsrt's Avatar
It'll do 12s if you can drive and put a set of sticky tires under it..
bluebeastsrt is offline
Old 02-24-2015, 01:11 PM
yurizx6r
yurizx6r's Avatar
That's nice to know. I'm running Nitto 555's (255 40R 17's), soI will probably be in the 13's. Which is fine.
yurizx6r is offline
Old 02-24-2015, 04:19 PM
88 orangepeel notch
88 orangepeel notch's Avatar
If that car won't do 12's, I'd leave it there lol.
Give us some details...... tranny, gears, car weight, etc. If you can pull a decent 60' you should be mid 12's fairly easy.
Alright, 13.2 first pass, 12.7 by the end of the night.
88 orangepeel notch is offline
Old 02-24-2015, 07:00 PM
yurizx6r
yurizx6r's Avatar
Engine: BBK CAI, C&L 73mm MAF, 70mm TB, Trickflow intake/heads/stage 1 cam, 30lbl injectors, stock bottom, MSD 6AL box, 3G alternator, 9mm spark plug wires, all polyurethane mounts, Bama Chip (will tune once I have heads done), long tube headers, off road H pipe, and Flowmasters Cat back.
Drive train: T5 transmission with Ram HDX clutch, Steeda short throw shifter, Maximum Motorsports clutch cable and quadrant, aluminum drive shaft, Yukon axle splines with 5 lug arp conversion, and 3.08 final gear ratio.
Suspension: Eibach sway bars, Ford racing B springs, Maximum Motorsports: subframe connectors, caster/caber plates, extreme duty rear lower control arms, power steering shaft, KYB struts, and Steeda strut tower brace.
Brakes: SN95 Cobra brakes front and back with all stainless steel lines and Hawk pads.
Weight reduction: fiberglass cowl hood, aluminum heads, smog delete, EGR delete, and spare tire is out.
Probably more, but that's off the top of my head really.
yurizx6r is offline
Old 02-25-2015, 07:12 AM
88 orangepeel notch
Nice mod list, and I'll stick with my times posted above. Those gears might hold you back a little. You should break into the 12's easily, but a decent gear and a set of big and littles with slicks, mid to low 12's with a 60' in the 1.7 - 1.6 range.
I don't know your driving skill, or if you've ever launched a car on slicks. But I can say it's a unbelievable feeling you'll want again once you've figured your car out.
Old 02-25-2015, 08:18 AM
yurizx6r
yurizx6r's Avatar
I think you're right. If I swapped my gears and put slicks on it I have to potential for 12's. I will be popping my cherry at the track, so as for skill.... lets just say novice. I expect 13's-14's based off my gears, tires, and skill level. If I get in the 13's (which I think is reasonable) I'd be pretty happy. If I do go with gears, I'm thinking 3.55's would be just about perfect. I'm always driving on the highway and I like the gas mileage of the 3.08's.
yurizx6r is offline
Old 02-25-2015, 09:17 AM
yurizx6r
yurizx6r's Avatar
One other question, what timing do you guys start out out with heads and and a cam like that (Trick Flow Twisted Wedge and Trick Flow stage 1 cam)? 10 degrees then work my way up?
yurizx6r is offline
Old 02-25-2015, 02:04 PM
yurizx6r
yurizx6r's Avatar
Scratch that, my buddy who's selling me the heads has a Ford E303 cam. I guess it's fine to take that too for $100 bucks? Would anybody see any benefit or point for spending an extra $120 for the TFS stage 1?
yurizx6r is offline
Old 02-26-2015, 10:56 AM
88 orangepeel notch
I'm not the most knowledgeable on cam selection, but you have a good intake, head setup, I'd research some better options for a cam as it's one of the most important parts in a build. With your setup, I'd even consider a custom grind for little more money. You have some $$$ wrapped up in there now, don't skimp on the cam.
Old 02-27-2015, 01:11 PM
yurizx6r
yurizx6r's Avatar
Forgive me for not starting a new thread, but I have another question............... I got all my parts last night. The heads look great, but I'm wondering which head gasket to go with?
Trick Flow suggest http://www.summitracing.com/parts/fe...FQyEaQodY68AMg
My buddy suggested http://www.summitracing.com/parts/fel-9333pt1
I also saw: http://www.americanmuscle.com/frpp-h...kets-7995.html
I'm thinking a composite would be the best for used heads and since I'm not going to send my short block to the machinist. Eventually, I will buy a stroker short block, but years from now. I just want a gasket that will last and not leak. Thoughts?
yurizx6r is offline
Quick Reply: Stupid fuel pressure regulator question
