New heads, but something is wrong
Old 03-22-2015, 06:44 PM
64bit
64bit's Avatar
take the god damn intake off before you kill yourself.
64bit is offline
Old 03-22-2015, 07:21 PM
yurizx6r
yurizx6r's Avatar
Already on it. I'm not doing that again. Hell no.
yurizx6r is offline
Old 03-22-2015, 07:28 PM
yurizx6r
yurizx6r's Avatar
Oh.....my.......God. Jupiter's *****, this isn't a simple vacuum leak.
Attached Thumbnails New heads, but something is wrong-img_20150322_194355.jpg   New heads, but something is wrong-img_20150322_194442.jpg
yurizx6r is offline
Old 03-22-2015, 10:05 PM
64bit
64bit's Avatar
like I said before... you probably slipped the intake gasket.
this is why I RTV my **** in place.
64bit is offline
Old 03-23-2015, 05:57 AM
yurizx6r
yurizx6r's Avatar
Oh don't worry, I'm doing it that way next time. I just hope I didn't do any damage to the motor.
yurizx6r is offline
Old 03-23-2015, 01:10 PM
AMAlexLazarus
Former Sponsor
AMAlexLazarus's Avatar
op - Sorry to hear about the trouble you're having nailing everything down here but it's sounding like you're working in the right direction. Have you shot Bama a call about this at all? Their guys have built some pretty ridiculous 5.0's over the past few years and I'm sure they'd be happy to get a tune on this for you. Let me know if there's anything I can do on my end to help out in the meantime.
Alex
AMAlexLazarus is offline
Old 03-23-2015, 03:14 PM
64bit
64bit's Avatar
Alex
FWIW, i wouldn't let Bama tune my radio.
I've seen what you guys sell as "tunes". You should re-label it as "toons".
64bit is offline
Old 03-23-2015, 07:17 PM
yurizx6r
yurizx6r's Avatar
I didn't have time to pull the lower manifold off because before I put some fresh oil in it (with some seafoam), did a coolant pressure test, and a compression test. By the time I finished I had another appointment and I had to put the sockets down.
When I pulled the upper off "chocolate milk shake" came out of the vacuum lines. I stuck a camera down to the valves and all looked clean, but there was some coolant in cylinder #7. Surprisingly, the radiator stayed at 16 PSI and did not drop.
The compression test went as followed:
1. 100
2. 0
3. 165
4. 155
5. 0
6. 0
7. 170
8. 140
The radiator PSI stayed the same for all cylinders except for #7 where the pressure went up from 16 PSI to 17 PSI. Cylinder #7 also continued to spray out coolant for each test.
Perhaps the push rods are too tight? I did half a turn past zero lash, maybe I should do it again, loosen all the push rods for a half hour, and do quarter of a turn then redo the compression test. When I did a compression test 6 months ago with the stock heads, my lowest number was 185 and my highest was 195.
Tomorrow I will finished taking the lower off and see whats up. So far I was thinking that it was just the lower manifold, but signs seem to be pointing to a head gasket. I find this astonishing because I used a composite head gasket. WTF!?
yurizx6r is offline
Old 03-23-2015, 08:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Alex
his issue has nothing to do with a tune......coolant in the oil as stated by 64bit it most likely is a intake gasket issue.....so the op has no need to waste his time calling bama to straighten pout a mechanical issue......which tunes don't fix fyi
mjr46 is offline
Old 03-23-2015, 09:03 PM
yurizx6r
yurizx6r's Avatar
Hey if they want to sponsor me a brand new motor to drop in I'm down. lol I'll take donations to the "Save the Fox Foundation." hahaha
yurizx6r is offline
Quick Reply: New heads, but something is wrong
