Possibly a bad tps?
Old 06-16-2015, 09:20 PM
StalkerGT
StalkerGT's Avatar
I have never done a koeo/koer test..is it a pain to do?
StalkerGT is offline
Old 06-16-2015, 10:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
http://sbftech.com/index.php/topic,2471.0.html
mjr46 is offline
Old 06-17-2015, 05:15 AM
StalkerGT
StalkerGT's Avatar
Thank you! I will let you know what happens
Old 06-22-2015, 03:24 PM
StalkerGT
StalkerGT's Avatar
Ok so I swapped out the tps with one I had on a stock throttle body I had laying around...set the tps to 0.90 and it went over 4.00 volts at wot. Did a base idle reset and still the same problem. If i hit wot while the car is sitting it does the same thing as when I'm driving. When it gets to about 3k rpm's is when the problem happens. Could it be a spark issue? Has new plugs, cap and rotor, new fuel filter, fuel pressur is where it should be. The ignition coil is new also. Possibly a bad pip in the distributor? Such a pain!! Also does a base idle reset need to be done every time the tps is adjusted?
Old 06-22-2015, 09:30 PM
mjr46
mjr46's Avatar
tps does not need constant adjustment................, .9x setting is a myth......anything from .7-1.0vdc is fine
mjr46 is offline
Old 06-22-2015, 09:44 PM
StalkerGT
StalkerGT's Avatar
Ok gotcha...does it seem like an ignition problem to you?
Old 06-23-2015, 06:47 AM
mjr46
mjr46's Avatar
it's possible.......hard to diagnose such over the net without going for a ride.......also if you have cats on it still make sure none are restricted
mjr46 is offline
Old 06-23-2015, 07:42 AM
StalkerGT
StalkerGT's Avatar
No cats on it..smog pump has been removed also. I did have a problem about 2 years ago where it was doing something a little similar to this, but not this bad. I swapped out the distributor and it ended up fixing the problem. I just don't remember it being at wot. That's why I'm kinda leaning towards the pickup in the distributor now...it was a used distributor I put in back then
Old 08-27-2015, 08:40 PM
StalkerGT
StalkerGT's Avatar
So I swapped out the distributor today with a new stock one and still having the same problem...new distributor, cap and rotor, ignition coil, plugs and wires are fine, new fuel filter, fuel pressure is perfect, I'm stumped! Could the maf cause the car to break up and feel like it has a loss of power? It has an sn-95 maf on it currently.
Old 08-27-2015, 10:38 PM
Urambo Tauro
Urambo Tauro's Avatar
Is the MAF OEM? Aftermarket units don't have a great track record from what I've heard. It could need cleaning, especially if you have an oiled air filter like a K&N.
Urambo Tauro is offline
Quick Reply: Possibly a bad tps?
