Possibly a bad tps?
Old 06-15-2015, 03:19 PM
StalkerGT
StalkerGT's Avatar
Default Possibly a bad tps?
So I'm having a problem at wide open throttle...the car will kind of sputter and not really rev too good at wot. It even backfires sometimes if I hold it at wot while driving. The car runs really good and idles fine otherwise. This problem use to happen only once in a while but is doing it all the time now. Timing is at 12 degrees with spout out. Not sure if tps is bad...
StalkerGT is offline
Old 06-15-2015, 03:56 PM
jwog666
jwog666's Avatar
bust out a meter and check it, or take it in and have someone check it for you. you could also be going lean, check fuel pressure, and MAF for contamination
jwog666 is offline
Old 06-15-2015, 04:40 PM
StalkerGT
StalkerGT's Avatar
Fuel pressure is fine, I have a fuel pressure gauge. What should the voltage be on the tps?
Old 06-15-2015, 04:42 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i always try and set the tps to .99 might need to jog the holes out a little for it to get there
rmodel65 is offline
Old 06-15-2015, 07:34 PM
StalkerGT
StalkerGT's Avatar
I will have to check the voltage on it as soon as the rain stops here. Is it possible to have a code even though the engine light isn't on?
Old 06-15-2015, 07:39 PM
jwog666
jwog666's Avatar
with obd 1 your lucky to get a code at all, if the failure is within the operational range it will not set a code, obd1 didnt use a rationale check
jwog666 is offline
Old 06-16-2015, 08:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
why?........setting tps to a specific voltage is a myth and does nothing if you understand the programming doc for the eec iv, anything between .7-1.00 vdc is fine.
mjr46 is offline
Old 06-16-2015, 08:53 AM
88 orangepeel notch
88 orangepeel notch's Avatar
When testing the TPS for voltage, remember to also do a sweep test looking for dips or spikes in voltage.
88 orangepeel notch is offline
Old 06-16-2015, 07:05 PM
StalkerGT
StalkerGT's Avatar
So how will I know if the tps is bad when I check the voltage?
Old 06-16-2015, 08:35 PM
mjr46
mjr46's Avatar
run a koeo/koer test and see if a code comes back for tps or do a manual sweep test with a dvom
mjr46 is offline
Quick Reply: Possibly a bad tps?
