95 GT 302 - GT40P UPGRADE-RUNNING LEAN!
no egr on this motor. also not lean at idle, this is its first run, not even broken in yet. shut it down because got hot. and timing might be off some, again it is not even broken in yet so timing has not been set, just roughed in. i think it is related to the upper intake or vac lines.
Found the problem. in the new trick flow elbow adapter we drilled and tapped the egr hole. but 1 of the bolt holes to bolt the EGR tube on was a through hole and not plugged. runs better now but not perfect.
it shakes really bad at idle, which it doesnt idle well. runs pretty good at higher rpm. all vacuum lines are good or plugged.
only codes being thrown are for EGR - has none and Thermactor solenoids (bypass & diverter) which all the smog is removed. those dont need to be tricked or anything correct? car does haven the EGR simulator also. i believe it is an ignition problem. but all new plugs and wires, i keep playing with distributor but cant get it out of it. firing order is correct for HO & E303 cam. IAC is clean.
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
