Need help on engine
Old 01-05-2004, 11:35 PM
ECR5.0
ECR5.0's Avatar
Default Need help on engine
I am looking to put in the gt-40 crate long block engine from summit. It has 345 hp with a b303 cam, but it says its only for a manual tranny. I have an auto AOD tranny. Can i still uses this engine?
ECR5.0 is offline
Old 01-05-2004, 11:39 PM
vfast
I ♥ Acer
vfast's Avatar
yes..just put in a 2500 stall convertor
vfast is offline
Old 01-05-2004, 11:43 PM
ECR5.0
ECR5.0's Avatar
so the teeth on the back of the engine will match up with the teeth on the tranny, just as long as i have a stall converter ill be fine?
ECR5.0 is offline
Old 01-05-2004, 11:51 PM
nemethjames1
nemethjames1's Avatar
2500RPM might be a bit much...
nemethjames1 is offline
Old 01-06-2004, 03:24 AM
ECR5.0
ECR5.0's Avatar
what size stall should i go with, and i just wanted to make sure one more time that this engine will work with my trans and the flywheel thats on the back of the engine
ECR5.0 is offline
Old 01-06-2004, 03:36 AM
Quik
Quik's Avatar
i have a 3000 holeshot and i wouldnt go less. especially with future mods.
Quik is offline
Old 01-06-2004, 07:35 PM
mkspeed26
mkspeed26's Avatar
or you could just put in a t-5!! i guess it is just a preferance. i dont know AODs though, only sticks.
mkspeed26 is offline
Old 01-06-2004, 08:34 PM
n2o44
n2o44's Avatar
autos can be just fine with some modding , and with a good shifter a lil safer to miss a shif obviously , the most breaking newish stuff is screwing with the electrinics of a newer auto via a tweecer or something , imagine a auto that shifts fine most of the time a lil harder when you get on it and when your really on it like wot , ill shift like a full built racing trans slamming gears , since its electrinic it has more inputs on whats going on and can be more fine tuned
n2o44 is offline
Old 01-06-2004, 08:36 PM
BLKSTANG9879
BLKSTANG9879's Avatar
Is it a everyday car. If it is i would go with the 2500 stall.
BLKSTANG9879 is offline
Old 01-06-2004, 10:39 PM
Obsol3te
Obsol3te's Avatar
is a T5 tranny good?</P>
i have one in my car, is it one of the best man. trans u can get?</P>
or is it just like a BRAND or something, or are there different versions?</P><edited><editID>Obsol3te</editID><editDate>37992.8616666667</editDate></edited>
Obsol3te is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Need help on engine
