Please Help.Speedo Recalibrati
How hard are these to put in exactly?</P>
Where do they go, and could a "noob" put one in?</P>
p.s. i know which way to turn a wrench </P><edited><editID>Obsol3te</editID><editDate>37995.9177662037</editDate></edited>
from my experience i did mine when i had the tranny out. mine of course is an aod. there is a door at back of the tranny.[if you look at it from tail to front its on the left] inside is the gear. youll need to remove the door and pull out the gear. swap gears reinstall. you can probably do this inthe car. on a manual i think you need to change the driven gear also
