what size throttle body o
Old 04-29-2003, 05:42 PM
DougBlevins
DougBlevins's Avatar
Default what size throttle body o
i put a 70mm TB on my 5.0 and was wondering if that's too big. my car has 1 5/8 equal length shorties and an H-pipe so i figured 70mm would b ok, what do all ya'll think, or hopefully know.
DougBlevins is offline
Old 04-29-2003, 06:19 PM
91GT5.0
91GT5.0's Avatar
Like I said in the other post, you would benefit more from a 65mm on a pretty much stock car than you would a 70mm. My friend has a 306 w/ f-cam, Powerheads, RPM intake, 76mm MAF, 24lbs-ers, full exhaust, and 3.73's. His car got considerably faster when he switched from a 70 to a 65
91GT5.0 is offline
Old 04-29-2003, 06:52 PM
kornfan_88
kornfan_88's Avatar
Can I just bolt on a 65mm throttle body without doing anything else? I know I have to do the egr spacer, right?
kornfan_88 is offline
Old 04-29-2003, 07:19 PM
91GT5.0
91GT5.0's Avatar
You can bolt it on, you do have to get a bigger spacer, or bore out your stock one. You don't *have to*, but anything you feel on a stock car, which won't be all that much, will be even less w/o a matching spacer.
91GT5.0 is offline
Old 04-29-2003, 08:32 PM
spike306
spike306's Avatar
don't forget that by putting that on, your forcing more air into the stock heads. it will be more afective with some good heads on there
spike306 is offline
Old 06-04-2003, 01:18 AM
mustang50
mustang50's Avatar
depends on your setup. I have a 75mm throttle body.
mustang50 is offline
Old 06-05-2003, 11:39 AM
89muscle
89muscle's Avatar
gop with the 65 mm because the airflow will be much faster.
89muscle is offline
Old 08-10-2003, 07:23 PM
stalker92
stalker92's Avatar
I have a 70 mm throttle body with a trick flow inathke manifold, with bbk equal lenth headers, o/r h-pipe will the 70 mm hurt the car? would a 65 be even better? Im also thinking about the future when i get a bigger motor and things like that.
stalker92 is offline
Old 08-10-2003, 08:37 PM
Sean
Sean's Avatar
I would go with a 65, unless you are going with some sort of forced induction.I have a 65 on my track heat with 76mm C&L,it runs great!
Sean is offline
Old 08-10-2003, 09:11 PM
roush97
roush97's Avatar
What's the stock size on a "91 5.0 GT?
roush97 is offline
Quick Reply: what size throttle body o
