Rear camber..
Old 12-24-2005, 10:41 PM
Curb
Curb's Avatar
Default Rear camber..
Does anyone offer a rear Camber kit for a fox? Im looking at stangsuspensions camber/caster kit... Is that only for the front? Stupid N00b question I know. Im just lost when it comes to suspension...
Curb is offline
Old 12-24-2005, 10:42 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: Rear camber..
The rear suspension alignment isn't adjustable. If something is out badly it normally means something is worn or bent.
ZachW04Stang is offline
Old 12-24-2005, 11:14 PM
Curb
Curb's Avatar
so theres nothing I can do when I lower my fox? Thats what I was trying to get at...
Curb is offline
Old 12-24-2005, 11:36 PM
primetime5.0
primetime5.0's Avatar
you dont need to adjust the camber when lowering the back because its a solid axle, not like the front
primetime5.0 is offline
Old 12-25-2005, 01:18 AM
waxyourboard
waxyourboard's Avatar
Your rear lowering is just going to be a set of springs, your caster/camber will always be the same... straight. Unless you hit something nice and big and bend something
waxyourboard is offline
Old 03-27-2008, 04:36 AM
Jfsram
Jfsram's Avatar
It's generally a good practice to check pinion angle after lowering the rear.
On a Mustang this doesn't seem to be an issue.
Jfsram is offline
Old 03-27-2008, 07:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you'll be fine in the rear when lowering it....no adjustment needed for rear only fron end alignment will be neccessary
mjr46 is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
09-30-2015 10:13 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear camber..
