battery drain
RE: battery drain
The battery is brand new because the old battery did not hold a charge at all. when it drained down I did the fast charge and when it drained down again i did the slow 2 amp charge. and the bat still drains after a day of sitting. the alternator is about a year old. and I ran A wire to the alternator to the neg side of the battery. and nothing happened. when I test the voltage of the battery when car is running it only says it is at 12.1 to 11.5.
Could there be a short causing the alternator not to charge the battery and make the battery die when sitting for a day?
RE: battery drain
If that is the voltage with the engine running, then the alternator is not charging at all. You don't mention the year, but I'm assuming it has an internal voltage regulator. Your problem could be the alternator, or regulator, or a wire, or a fuse, or a fusable link, or a bad connection. First check all of your fuses. If there isn't power coming from the battery to excite the field, it will not charge. If it's not a fuse or a broken or loose wire, get the alternator tested at a parts store. If it does have an external regulator, you may want to change that to test it.
