Can you make a mustang engine
Old 01-29-2004, 08:59 PM
MartyE12345
MartyE12345's Avatar
Default Can you make a mustang engine
I have a 5.0 with a couple of bolt on modifications but i wonder if u can make a mustang engine rev higher because they rev kinda low
MartyE12345 is offline
Old 01-29-2004, 09:09 PM
619socalstang
619socalstang's Avatar
for a V-8 there pretty good but with some new forgedpistons, Manely alu.rodswith a cmplete rebuild and some internal balanceing you could get around 9000 rpm also need profromane ignition and valve train.
619socalstang is offline
Old 01-29-2004, 09:29 PM
Ormist
Ormist's Avatar
What is a basickly stock 89 GT supposed to idle at (rpm) I have Flowmasters Exaust, E chip, Offroad H pipes and K&amp;N Air filter and no Cadalidic Converter* (If it makes a difference)..</P>
Ormist is offline
Old 01-29-2004, 10:28 PM
five0
five0's Avatar
650?
five0 is offline
Old 01-29-2004, 10:30 PM
Ormist
Ormist's Avatar
I idle about 750-800...
Ormist is offline
Old 01-29-2004, 11:26 PM
makarovboy
makarovboy's Avatar
To get back to your original question, ormist, you can de-stroke it. Turns a much higher rpm, 10,000rpm range. Short stroke equals insanely fast piston speed in the bore.
A better option (and cheaper), is h/c/i, with the cam and the intake being the major players. But beware, if you select a cam in the 3500 to 7000rpm range, you ain't gonna like it on the street, and with an intake such as the edelbrock rpm or rpmII with that cam, it's not a streetlight to streetlight racer, as you're not even going to come on the pipe until 3500rpm.
Strokers are the way to go, lots of torque down low with moderate h/c/i, killer street ride plus bad track times.
makarovboy is offline
Old 01-30-2004, 01:32 AM
Quik
Quik's Avatar
i seen one in an article rev to around 9g it was a 306. that had a nice cam,youll need heads that can flow extremely well, strong springs, lightweight pistons and arms. flowing intake. a strongbottom end
Quik is offline
Old 01-30-2004, 05:22 PM
mkspeed26
mkspeed26's Avatar
torev higher you need power up there. so you need to get h/i/c that flowat high rpms. if you stroke the engine the piston has to move farther, so your rpms will drop. if you destroke it the piston moves less so it can get more rpms. and if you plan on running high rpms you need a better ignition system.
mkspeed26 is offline
Old 01-30-2004, 07:27 PM
tchamber
tchamber's Avatar
Ahh, cmon, just get stiffer valve springs
tchamber is offline
Old 01-30-2004, 09:22 PM
mkspeed26
mkspeed26's Avatar
</P>
are the stock ones really that weak??</P>
Quick Reply: Can you make a mustang engine
