HELP!! need to knows whats vib
Old 01-30-2004, 05:00 PM
Pitviper100
Pitviper100's Avatar
Default HELP!! need to knows whats vib
Ok ive analyzed it down to this... my engine is fine,if I have my clutch in and rev it up nothing sounds abnormal all is fine... the vibrating only happes while im in gear... it doesnt lsip in gear doesnt have difficulty geeting in gear the car just vibrates funny when in gear... it does this through all 5 gears and this just started yesterday i dont have any idea what is causing it.. ive even coasted the car while driving to see if it was the tires out of aligment ect ect has something to do with the transmission i think... can anyone help?
Pitviper100 is offline
Old 01-30-2004, 05:42 PM
mkspeed26
mkspeed26's Avatar
how are your engine and tranny mounts?? that sounds like the problem to me
mkspeed26 is offline
Old 02-08-2004, 01:43 AM
yardbird
yardbird's Avatar
I had that problem once and it was where some of my bolts that hold the driveshaft to the rear worked loose and it would vibrate violently at higher rpm.Ive also heard of the weights falling off of peoples driveshaft that are supposed to balance it not sure what to do about that but it would be a good exscuse to upgrade to an aluminum one!<IMG src=smileys/smiley16.gif border="0">
yardbird is offline
Old 02-08-2004, 01:55 AM
71455vert
71455vert's Avatar
I would check the u joints if it starts to bind it will start as a vibration. &amp; then grenade or crack the tailhousing of the tranny.
71455vert is offline
Old 02-08-2004, 02:20 AM
grabbem88
grabbem88's Avatar
check the driveshaft bud,put it on a lift if you can.
grabbem88 is offline
Old 02-08-2004, 04:14 AM
hotrodman
I ♥ Acer
hotrodman's Avatar
i had a broken press plate that drove me crazy..vib.like crap..thought it was my rear end at first,, than my tranie ,,looked up in the fork area,i could see it...
hotrodman is offline
Old 02-08-2004, 11:43 PM
diablo9861
diablo9861's Avatar
Check your fan clutch, i had that happen to mine just recently, when i would get to about my normal shjifting points the whole damn car would shake and be loud as f***, or on the highway it would be extremely bad, check your bearings and stuff in that, it worked for mine oncei replaced it with a new one. Hope you fix it.
diablo9861 is offline
Duncaan
13
04-05-2013 11:28 PM
89CONVGT
09-25-2012 11:50 AM
yoyo8750LX
03-08-2011 03:01 PM
coolbreezex82x
04-06-2010 07:39 PM
bchataroo
08-22-2007 05:37 PM
Quick Reply: HELP!! need to knows whats vib
