Water Pump Pulley Crooked
Old 11-04-2007, 01:57 PM
Hawaii 93 Stang
Hawaii 93 Stang's Avatar
Default Water Pump Pulley Crooked
Hey Guys. I needed to replace the fan clutch. Took off the fan and clutch, removed old clutch, cleaned up the fan, install new clutch to fan. Ready to put it back on and discovered the water pump pulley was crooked. I do know the 4 bolts to the fan holds down the pulley. Now my question is if there a way to straighten it out without taking the belt off?? Still learning here!![:@]
Hawaii 93 Stang is offline
Old 11-04-2007, 02:07 PM
5.0stanger
5.0stanger's Avatar
Default RE: Water Pump Pulley Crooked
You should take the belt off, it would be easyest.
5.0stanger is offline
Old 11-04-2007, 02:10 PM
jhall01
jhall01's Avatar
its not hard to take the belt off. n how is your belt staying on if the pulley is crooked. if it was just me i would go n get another pulley since you have everything off. but thats just me
jhall01 is offline
Old 11-04-2007, 02:15 PM
5.0stanger
5.0stanger's Avatar
ORIGINAL: jhall01
The reason why his pulley is crooked is because he took the bolts out of it to remove the fan.....he doesn't need a new pulley. Just needs to remove the belt so he can bolt it all back together.
Old 11-04-2007, 02:17 PM
jhall01
jhall01's Avatar
Oh i gotcha now lol. im tired leave me alone lol.
jhall01 is offline
Old 11-04-2007, 02:20 PM
Hawaii 93 Stang
Great guys!! Thanks will do!!! That's what I was thinking too!!! Off to go fix her now!!
Old 11-04-2007, 02:23 PM
5.0stanger
5.0stanger's Avatar
Good luck
Old 11-04-2007, 02:28 PM
dimebag
dimebag's Avatar
i know it was a pita to get the bottom bolt or two... with the belt still on... taking the belt off makes life alot easier
dimebag is offline
Old 11-04-2007, 03:41 PM
stang8689
stang8689's Avatar
Damn that is the easiest belt to remove
stang8689 is offline
Old 11-04-2007, 08:23 PM
dimebag
dimebag's Avatar
you should try one of those full size chevy vans... do a belt on one of those... i had to do an alt and a belt...yup, big pain in the ***...
im talkin the vans w. the short *** hood, and the dog box...
damn i hated workin on those, lol
dimebag is offline
Quick Reply: Water Pump Pulley Crooked
