Is there anything that i need to pay close attention to when im changing injectors? such as fuel pressure or anything.if there is fuel pressure is there an easy way to bleed it off safely. just wanna make sure because i got my injectors in and will be putting them on. any help will be appreciated.
if new injectors they should have new orings and caps and be fine if used you want to get new o-rings and caps to be on the safe side with bigger injectors..
you should have a bleed off on the fuel rails, what fuel rails do you have???and if there is any pressure in it shouldnt be much..when i changed mine i used the bleeder off it...
