Jasper's weight reduction sticky?
Old 03-30-2008, 05:57 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
Default Jasper's weight reduction sticky?
Where did it get to? I can't find it.
rust_stang is offline
Old 03-30-2008, 06:33 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Jasper's weight reduction sticky?
https://mustangforums.com/m_3255919/tm.htm
PRO50SC is offline
Old 03-30-2008, 06:43 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
Ah,the link I wanted no longer works
list of what stuff weighs after its taken off
http://users.adelphia.net/~mustang-9...duction%20Top/]list of what stuff wieghs
well I'll ask it on this thread then.. how much does the front seats and rear seat in a notchback fox weigh?
Old 03-30-2008, 06:45 PM
w8less
w8less's Avatar
thanks i noticed that a while back and tried finding it with no luck....[&:]
w8less is offline
Old 03-30-2008, 06:48 PM
w8less
w8less's Avatar
however i found this just now i am going to add to it
Stock 302 Shortblock with crank, rods pistons but no cam, no timing chain, no timing, no timing cover and no oil pan was 184.85 pounds.
Stock 302 Bare Block w/ Main Caps, 125.70 LBS
World Class T5 out of 85 SVO, not FULL of fluid but I think it still has some in it 71.55 LBS
Passenger Seat out of 85 SVO, cloth style, with seat track & manual lumber inflators, 44.25 LBS
SVO (might be same or similar to other 79-86 bumper reinforcement?), Steel Bumper Reinforcement, 30.70 LBS
79-90 Fender, no moldings or anything, 13.70 pounds
Front Bumper Mount Shock deals with bolts, 10.75 pounds
Steeda Drag Front Sway Bar for 79-93, has the bushing mounts but no endlinks, 13.30 pounds
Trick Flow Twisted Wedge Head fully assembled with Crane Energizer 1.6 Roller Rockers, no port work, 33.65 pounds, 30.05 pounds bare
E5 Head fully assembled with stock rockers, no port work, 53.85 pounds
Crane Energizer 1.6 RR's with Poly Locks, 7.05 pounds
Stock 87-93 Hood with latch and not much paint, 41.05 pounds
85 SVO Leather E Brake Handle, no hardware, 2.05 pounds
Weighed the center arm rest, 6.90 pounds, the 87-93 center console without the armrest and missing the ash tray door & shifter bezel is 5.45 pounds, 12.35 total with arm rest. Thats including the power mirror switch, ac bezel and radio frame.
SVO Steering Wheel, no leather wrap on the wheel itself, 5.55 pounds
Griffin Circle Track Aluminum Raditor, part number 1-26272-X, 15.45 Pounds
Stock HO Intake, nothing in it but a couple of sensors and the TB studs, 33.15 LB's
Edelbrock Performer 5.0 Intake, bare, 38.90 LB's
Smog Pump with the first part of line to the valve thing, no other piping, 8.45 LB's
Horns, 1.35 LB's
Windshield Wipers, 1.30 LB's
Wiper Arms under cowl panel, 1.85 LB's
Wiper Motor, 3.95 LB's
Cruise Control Canister thing up in the fendor, 2.50 LB's
AC Compressor w/ Small AC Bracket, 18.00 LB's
Cargo Cover, 4.90 LB's
94-95 Factory Strut Tower Brace, no hardware, 7.20 LB's
Factory 92-95 Mini Starter, 7.80 LB's
Harwood 3 Inch Pin On Cowl Hood, 15.70 LBS
Cobra R SVO Bolton Hood, no latch, unknown brand, 29.75 LBS
Insulation in hatch (not including attached to carpet) on 87-93 hatcback car, right at 10 LBS
PA Super Comp C4 w/ SFI Bellhousing, no fluid, 116.8 LBS
Continental 3800 Stall Converter, 30.75 LBS
Some stuff from a 95 GT:
Spare, 19.85 LBS
Jack, 5.75 LBS
Insulation in trunk, 1.70 LBS
Lug Wrench, 1.65 LBS
T56 out of a 93 Z28, probably similar weight to one for a Mustang Im sure, no bellhousing, no fluid, no clutch fork, 119.20 LBS
97 Cobra Wheel 17x8, 22.45 LBS
Weld Pro Star 15x8, 5 Lug, 14.05 LBS
Stock T5 Bellhousing, 10.85 LBS
FMS Aluminum Driveshaft, 13.70 LBS
Stock H Pipe w/ 4 Converters, 33.65 LBS
Offroad H Pipe, 17.35 LBS Front fog light bar, with lights - 20lbs A/C compressor - 17lbs 10 hole wheel with 235/60/15 SLX5000 tire - 46lbs MM Strut Brace - 8 lbs
w8less is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Jasperstang308
[sm=icon_stickpoke.gif][sm=icon_rofl.gif]
PRO50SC is offline
Old 03-30-2008, 06:54 PM
WhiteWindsor
WhiteWindsor's Avatar
I should have read it a while back. My race weight todaywith my big *** was #3370. Probably the easiest thing is for me to go on a diet lol.
WhiteWindsor is offline
Old 03-30-2008, 06:56 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
How much does the front seats and rear seat in a notchback fox weigh?
Old 03-30-2008, 07:05 PM
w8less
w8less's Avatar
hey if any of you guys want to weigh anything else let me know and i can add it in
w8less is offline
Old 03-30-2008, 07:07 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
how about my last post[&:]
Quick Reply: Jasper's weight reduction sticky?
