can some one help me ?
I got a 90 mustang gt with automatic and my problem is that I dont get enough power to the fuel pump I replace the fuel pump but still not working I replace all the relays on the car and nothing can please some one help me thanks!
Have you tried...
Has the inertia switch for the pump been tripped somehow? Reset the switch. Also, you can check the pump by the diagnostic plug. Ground the FP lead(far right lead on the test plug) and turn the ignition on, the pump should run. Hope this helps.
I tested the fuel pump wires and connectors and I did used a 12v light on the connector of the pump every time I open the ignition switch ligths up but you barely see the light on mmmmmhhh weird I test the pump directly to the battery and seems to be working well but not when I plug it to the connector it wont do nothing !
I tested the fuel pump wires and connectors and I did used a 12v light on the connector of the pump every time I open the ignition switch ligths up but you barely see the light on mmmmmhhh weird I test the pump directly to the battery and seems to be working well but not when I plug it to the connector I wont do nothing !
thanks you the man !!!!!!!!
I went under the driver seat and I pull the relay out and I went to buy a new one when I pull the connector out I did find one of the wires of the connector cut out I replace it now it runs but when I step on the gas kinda rattles and my check engine comes on but other the that thanks for the tips apreciate all the info thank you!!
