Chassis Ground Wires
Old 06-26-2009, 07:52 AM
Tony71502
Tony71502's Avatar
Default Chassis Ground Wires
How many ground wires are there on a 91 5.0 hatchback? I'm considering buying newer 4 Ga. ground wires while I'm messing with the charging system. Thanks.
Tony71502 is offline
Old 06-26-2009, 08:21 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
do this
http://www.my5oh.com/forum/viewtopic.php?t=95
you wont regret it. best write up on this ever. for battery i use 0awg and engine to ground i use 0 awg. everyhting else i use 4awg and i dont use the ground straps.
FivePointOhh is offline
Old 06-26-2009, 08:48 AM
Tony71502
Tony71502's Avatar
I was going to get the Taylor battery relocation kit with 1 ga. welding cable... will using 1 ga. welding instead of normal 0 ga. make a real difference? Was planning on 4 ga. grounds, 1ga. welding ground from battery, then a 4 ga. cable from 130 amp alt to solenoid.
One other slightly off topics question.. how should I go about modifying a wire that directly run off of the battery? The HID's I have run directly off of the battery just like a sound system would.
Old 06-26-2009, 09:14 AM
FivePointOhh
in limbo
welding wire is pretty nice, good fine stranded wire. i prefer audio wire because its more flexible and finer stranded which is bettery conductivity. over a long distance 3ft vs 20ft, yes big difference from 1awg to 0awg. when they measure resistance in wiring, it's over distance. 1 foot of 1awg would have the same resistance as 3 feet of 0awg. see what i mean?
Old 06-26-2009, 09:46 AM
Tony71502
Tony71502's Avatar
Taylor sells ground wires in 8 inch, 14 inch, and 18 inch length. I'll probably need to go to a different company, maybe back to PA performance, to get a longer cable from the battery post to the engine block. But would two 18 inch grounds for the block to frame be good? Then like a 14 inch to use from battery to frame, or would an 8 be better there. What is the 4g ground in the picture in the link you refer to... he said install one with the 3g alt.. where would this ground be connected to? Just the block? Is that a redundant block to frame ground he installed?
Old 06-26-2009, 11:33 AM
FivePointOhh
in limbo
well when you are doing the battery relocation you do, battery to frame, frame to block, (i also do an alt to frame...kinda OCD but makes me feel better) the frame to block one i hook up the eec ground to it as a common ground. thats how i do my loop. works wonderfully. no loss from accessories. great charging system.
Old 06-26-2009, 12:17 PM
Tony71502
Tony71502's Avatar
Where did you ground the alternator at? Anywhere on its casing?
For the EEC common ground, the original ground is over near the battery, correct? Did you run a ground from engine block to the EEC ground near the stock battery location?
Old 06-26-2009, 12:31 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
On the 87+ cars where is the stock location for the main battery ground?
projectresto83 is offline
Old 06-26-2009, 12:49 PM
Tony71502
Tony71502's Avatar
I'm quite positive it goes from battery to engine block.
Will eliminating this battery to block ground affect anything? Since the battery will be in the rear of the car and grounded on the frame.
I'm trying to order some parts here before the day is done so they at least ship out. What length grounds would I need for block to frame and anywhere else in the engine bay? All I can find premade are 8 inch and 14 inch 4ga. But I could get regular cable and cut it I suppose.
Thanks
Old 06-26-2009, 01:22 PM
FivePointOhh
in limbo
ok see if you can follow my routing.
battery in trunk >>> ground to frame >>> in engine bay, alternater housing to pass side frame rail>>> block to frame rail driver side>>> moved eec ground in stock location to the block to frame rail connection, common ground.
Quick Reply: Chassis Ground Wires
