My expensive build thread...
Old 08-06-2009, 08:44 PM
  #81
Tony71502
Tony71502's Avatar
Well, I did the MM subframes, MM strut tower brace, and MM K-member brace all at once. It made a world of difference, especially at high speeds during my high speed morning commutes to work.
I'll be selling this one pretty soon, as the MM K-member uses a two point brace instead of four.
Tony71502 is offline
Old 08-07-2009, 03:48 PM
  #82
5pointslow91
5pointslow91's Avatar
veryyy nice how much
5pointslow91 is offline
Old 08-07-2009, 11:57 PM
  #83
Tony71502
Tony71502's Avatar
Too much.
Anyways...
Here's my gruesome pics of the original 150K+ mile pistons...
Here's the "not fvcked up" cylinders....
Time to sleep or a hangover ensues....
Old 08-08-2009, 02:07 AM
  #84
302army187
302army187's Avatar
just a little burnt up, lol.
302army187 is offline
Old 08-08-2009, 01:24 PM
  #85
Tony71502
Tony71502's Avatar
Well, here is something interesting. Why would they weld the number 291 on the radiator support? Has anyone seen this before? Is it a part/vehicle type code or is it just someone leaving their mark?
Well, the engine bay is cleaning up nicely. I haven't started on the driver's side yet.
Does anyone know what these following two items are? The object with the bar code in the first picture, and the one with the pinkish wires under the radiator core support in the second picture.
Old 08-08-2009, 02:49 PM
  #86
ctgreddy
ctgreddy's Avatar
the first thing looks like a crash sensor for your airbags. no idea about the second one tho.
ctgreddy is offline
Old 08-08-2009, 05:24 PM
  #87
Tony71502
Tony71502's Avatar
I think you're right. There's another on the driver's side.
Does anyone know if I can just cut the sensor wires out of the harness? I don't want the airbag sensors. I also do not want to do something wrong by cutting the wires and then causing the bags to go off when connecting the battery. I've got no idea how the system works. All of my harnesses are cut open as I'm hiding/removing/changing things around. There won't just be two ugly snipped wires there.
Old 08-08-2009, 06:48 PM
  #88
smacked1
smacked1's Avatar
where in pa are you
smacked1 is offline
Old 08-08-2009, 09:53 PM
  #89
Tony71502
Tony71502's Avatar
About 25 minutes south of Pittsburgh. The "South Hlls". Go Steelers, but more importantly, GO PENGUINS!!!!!
Old 08-08-2009, 10:22 PM
  #90
USMC1775
USMC1775's Avatar
If you disconnect the battery, cutting the wires shouldnt matter, however youll probably get a warning light when you put it all back together
USMC1775 is offline
Quick Reply: My expensive build thread...
