What to go next? (Setup listed)
Hey there fellow mustang lovers I am currently working on my 88' stang for an explorer intake swap. While I'm at it I might even change the heads, cam, etc...
Here is my actual setup:
Speed Density
BBK Cold Air
65mm TB & EGR Plate
Explorer Upper & Lower Intake with phenolic spacer
24 lb. injectors
Ignition package from Performance distributors
Iridium spark plugs
Adjustable Fuel regulator w/ gauge
Underdrive pulleys
Battery relocated
EL BBK 1 5/8 headers
Prochamber hybrid pipe
Borla Mufflers
Question is simple: What would go after next? Thanks
Speed Density
BBK Cold Air
65mm TB & EGR Plate
24 lb. injectors
Iridium spark plugs
Underdrive pulleys
Battery relocated
Borla Mufflers
Good luck trying to drive laps with the drag launch springs! I'm running them in the front and they make my car drive like a cadillac. Anyways, with the exploder intake you're going to be choking anything more than a GT40 or P head so I'd say that's a great start. Contact Jay Allen @ CI (link is below) and see what he reccomends for a cam. He might reccomend you just (re)degree the stock cam or adding a set of 1.7rr especially if you want good driveability.
http://www.camshaftinnovations.com/
Ok thanks a lot about this insight! Quite interesting I'll look at that.
About the springs, yash I know they offer a weird driving feeling... bad unexperienced youth choice XD I got a set of MM Camber plates and struts waiting for installation though... Anyway, for me lapping is a long way from here
Thanks again!
Thanks again!
