Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 03:13 PM   #21
grindman620
grindman620's Avatar
Vehicle: 2008 Ford Mustang!!!!
So my goal in the next 6 months here while I wait for spring to come back is to get my suspension in order. Is this basically all I will need to support all the hp?
-weld in subframe connectors
-upper and lower torque box reinforcements
-upper and lower control arms
-springs
-adjustable shocks and struts
-panhard bar for cornering (not necessary)
-upgrade brakes
What should I do to "upgrade" the brakes?
__________________
2008 4.0
1993 5.0
grindman620 is offline   Reply With Quote
Old 10-20-2009, 03:16 PM   #22
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
IMO keep the stock fronts and get the disk rears. factory rear disk break set up + these brackets a company sells so you can keep your stock axels and wheels. unless you wanna spend money to go 4 wheel disk 5 lug conversion. thats a little more involved
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 10-20-2009, 08:09 PM   #23
grindman620
so you are saying that the front disc brakes should be sufficient? and that i should change out the drum rears to discs? i know there is an advantage to doing a 5lug conversion, but isnt it mostly for wheel options? not really a performance issue?
__________________
2008 4.0
1993 5.0
Old 10-21-2009, 12:01 AM   #24
nacanitihs
Vehicle: 1989, Mustang GT
well depends on what type of 5 lug swap you do
you can do a 5lug swap and keep drum rears (slight upgrade due to slightly larger front rotors)
you can do one that uses the sn-95 front and rear disks (upgrade)
you can do one that uses sn-95 cobra brakes (better upgrade)
or if you wanna keep 4 lug you can swap to thunder bird turbo coupe rear disks
__________________
SVO GT40x Aluminum Heads, FRPP F303 Cam, GT40P Intake, 3.73s, Full Exhaust and Suspension
http://i56.photobucket.com/albums/g1...ynosheet-1.jpg
275rwhp and 300ftlbs
nacanitihs is offline   Reply With Quote
50, cobra, difference, end, engine, gt, gt40x, heads, hp, kit, motor, mustang, tfsk514360350b, top, worth
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
