8.8 gears
Old 03-28-2010, 10:57 PM
oldno7
oldno7's Avatar
Default 8.8 gears
What gear ratio should i go i was thinking 3.73 for strip and hiway. Should i rebuild it while its open? What all do i need and should i posi tracktion? Would it all be hard for a first timer. Its pretty much stock for now.
oldno7 is offline
Old 03-28-2010, 11:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
answer is here:
https://mustangforums.com/forum/5-0l...bers-read.html
mjr46 is offline
Old 03-28-2010, 11:12 PM
mustangmancp
mustangmancp's Avatar
Id do 3.73s if I were you and i mean if you have the money to build up the rear it will allow you to launch the car at higher rpms and just be great insurance in the long run.
mustangmancp is offline
Old 04-06-2010, 06:23 PM
oldno7
oldno7's Avatar
Should I go 3.73 or 4.10 its a 87 5.0 stick.
oldno7 is offline
Old 04-06-2010, 06:31 PM
minnow81469
minnow81469's Avatar
3.73's will do you ok and dont forget to get speedo gears for the tranny
minnow81469 is offline
Old 04-06-2010, 08:54 PM
88foxGT
88foxGT's Avatar
If you are going to the track do 3.73s. If you are not and drive on the highway do 3.55s. I would definitly get a rebuild kit from a website like 50resto.com etc....when you pull the differential out you can inspect it then and change if needed. Gears can be a tough project depending on your skill set. If you have never done this before make sure someone is on hand to help you.
88foxGT is offline
Old 04-06-2010, 09:01 PM
mjr46
mjr46's Avatar
4.10's, you'll thank me later
mjr46 is offline
Old 04-06-2010, 09:20 PM
AdderMk2
Banned
AdderMk2's Avatar
I'm putting 4.30's in.... hehehe
AdderMk2 is offline
Old 04-06-2010, 09:29 PM
raven_ghostwolf
raven_ghostwolf's Avatar
The Capri in the video I posted recently has 5spd & 3.73s, great on the launch but I have driven on the highway too, running 75 mph steady the RPM's are up there more than I like, and you can forget fuel mileage I'd go 3.55s. If your car is going to see more track time than highway time then go for it you'll love the kick.
raven_ghostwolf is offline
Old 04-06-2010, 09:34 PM
mjr46
mjr46's Avatar
I'd swap my 3.73's for that, however, once I crack the bottle, the freaking thing is gettin close to redline , guess it'll be time for a tire size mod soon..lol
mjr46 is offline
Quick Reply: 8.8 gears
