MAF Sensor & Throttle Body
Old 05-20-2010, 11:08 AM
cholericfc
cholericfc's Avatar
Exclamation MAF Sensor & Throttle Body
Whats the best set-up for a car with 24lb. Injectors??????????
This Throttle Body in 70mm or 75mm?????????
http://www.latemodelrestoration.com/item/AF-70K
This Mass Air Meter??????????
http://www.latemodelrestoration.com/item/PMA-12579AF
Is their a better set-up for MY car???????? I was looking at Grantanelli 90mm MAF (((((((same price - didn't know if that was too much????????)))))
Check out the link in my signature below for more info on my car.
Thanks in advance!!!
cholericfc is offline
Old 05-20-2010, 12:06 PM
toms93lx
toms93lx's Avatar
the 75 should be plenty ....... i am running a 75 tb and 76 maf with 24s.....dont get the 70
toms93lx is offline
Old 05-20-2010, 12:08 PM
toms93lx
toms93lx's Avatar
how big is your upper plenum opening
toms93lx is offline
Old 05-20-2010, 11:13 PM
cholericfc
cholericfc's Avatar
Edelbrock Performer RPM
Old 05-24-2010, 02:46 PM
cholericfc
cholericfc's Avatar
bumppp
Old 05-24-2010, 03:04 PM
AdderMk2
Banned
AdderMk2's Avatar
you can get a 75mm TB off summitracing for about half of the cost of that one.
I still dont know why people are obsessed with using LMS as an aftermarket parts source, resto parts... sure
but summit is almost ALWAYS cheaper
AdderMk2 is offline
Old 05-24-2010, 03:11 PM
cholericfc
cholericfc's Avatar
So 75mm TB and a 75mm MAF is an ok set-up???
btw, it depends what your buying, 50resto sells some nice kits, summit does sell certain things for cheap.
Old 05-24-2010, 03:24 PM
AdderMk2
Banned
AdderMk2's Avatar
Its not ideal, but there is nothing wrong with it. You never want your maf to be smaller than your TB, same size is ok-ish.
and i'll never buy anything from 50resto. their hidden shipping charges are ****ing retarded. Im not happy with their customer service, and i hate their website.
Summit however has already had several thousand dollars of my business, and I couldnt be happier with their service and personnel.
fwiw, you could get an LMAF for $90... new
AdderMk2 is offline
Old 05-24-2010, 03:29 PM
cholericfc
cholericfc's Avatar
its flat rate 15bucks. But, I order from the following
mustangsunlimited
50resto
summitracing
cjponyparts
or direct.
But, I never pin it down to one supplier
research prices than buy from the cheapest.
Old 05-24-2010, 03:38 PM
cholericfc
cholericfc's Avatar
SO, when it comes to the throttle body.
I don't think i can/should go bigger than a 75mm Throttle Body.
If I get a 70mm TB, than 75mm MAF will be perfect??????
If I get a 75mm TB, than an 80mm or 90mm MAF will be perfect????
hit me up.
Quick Reply: MAF Sensor & Throttle Body
