Head/cam upgrades on a carbed, Flat tappet 302
Looking for a little bolt on power cheap. (just like everyone else)
Im currently running a 1984 5.0 with MSD, BBK longtubes and H-pipe, Holley 600CFM with spacer, smog and A/C delete. She moves, but not like I want it too. Im finally getting some cash together to spend on the fox but with so many options i wanted to get some oppinions...
Heads...I wanna run cast heads strictly for the reliability and price. This is my daily driver....No race car but I want it to have some get up when I need it too.
289 Heads????
Anyone? I know some modifications must be done for steam holes but with the increase in compression is it worth it? I belive the ports are slightly smaller but the increase in compression compensates..
GT40's????
Better than the 289 option? Everyone knows the Ford GT40's are a nice cheap head solution for the mild 5.0....But will the GT40's or GT40P's run on a carburated, flat tappet motor? Will I have clearence? Different push rods? Rockers? ect?....Would it be easier to convert to a roller? I do have a roller top end off an 86EFI should I consider swaping them?
Just looking for a little insight. Any tips, knowlage or techniques on this would be greatly appreciated.
Thanks in advance!
289 Heads????
GT40's????
Thanks in advance!
Well im just looking for a little extra, I figure im running just shy of 200 rwhp (Stock of this year was 175)
Im looking for somthing more along the lines of 250-300. I plan on doing heads and cam, but there is just so many options.
I dont know if it would be worth it to convert to roller lifters? Or what heads are compatable with my flat tappet, carbed setup?
Like I said, I have been toying around with the thought of the 289 heads, with a little machine work, OR find some GT40's and just go that route.
Any suggestions? Im not interested in Juicing or boosting, all motor. Looking to see what the best head/cam combination for my application. Keep in mind, Id like to stay with cast heads and this is a full summer daily driver.
Anyone done either head setup on their carbed 5.0? Any insight?
Thanks in advance!
Thanks in advance!
This section is non tech right? So is asking for advice on an engine combination the same as asking how to fix something? Or by non tech does that mean nothing related to tech stuff at all? In either case, I mean no disrespect by posting this...OP There are a lot of economy upgrades you can find on auction type websites. If you're doing your own work then that's really where you'll save money I think. I'm about to swap a 96 Mark VIII for an 86 Mustang GT and I'm gonna be looking for cheap initial upgrades just until I get my 393 stroker ready...!! You can also check the classifieds section on this site...!!
Well....It was in the tech section....and it got moved here.... I didnt post it here. All im looking for is a little advice not how to fix my car. Im sorry if its being placed in the wrong places, but like I said, I didnt put it here.
Well I'm not all that up on the push rod engines but I think I'm gonna do the Cobra top end kit just as a little power boost until I get the stroker ready...you could even do a supercharger kit. They go for like 1200-1500 bucks on ebay.
im fairly close to you and i have some fully decked out 289 heads for sale. ported, bowl blend, larger valves 1.94 1.6 valves, decked surface 50cc chamber, tapped screw in studs, guideplates and included springs.
all ready to bolt up less than 1k miles on them. PM if interested.
Thanks in advance!
Thanks in advance!
