What should i do next?
The car already has pulleys i left that out, The stock intake is still on there as well. I am looking for the next bang for my buck item. also mjr the car has full exhaust.
Also would it be noticeably better to change from a B&M ripper to a MGW shifter? anyone ever have both?
I know, I read that, hence, why I said get a real h/c/i then you'll need a real exhaust set up.....an intake and TB and appropriate maf could be a start but without a decent cam, just the p heads alone aren't gonna get you where you need to be, if you want to use the stock cam maybe run a 1.7 rocker
ah right on. I am already running a 1.7 rocker. Is there some sort of an adaptor to bolt on the intake to use on 95's to get the turn? Will i gain anything by changing the intake tb? What size tb and such should i run?
