What kind of HP can i expect?
Old 03-18-2011, 04:20 PM
91sLXeeper
91sLXeeper's Avatar
Smile What kind of HP can i expect?
I'm building a 302 and im wondering what kind of horse power i can expect both to the flywheel and the rear wheels. Its an 87 block with stock crank(all new bearings) and stock rods(also has new bearings) with flat top pistons with 4 valve relieves(+3cc volume). I have a hydraulic flat tappet cam in it from crane cams ( 276/276 .498/.498) Im going to be using gt40p heads from a 97 explorer (milled .010, port and polished, 3 angle valve job) with the trickflow valve spring upgrade kit and proform 1.6 roller rockers. for air/fuel im going with a Weiand street warrior high rise intake with a holley 650cfm electric choke. Ill be using an aluminum driveshaft and 3.73 rear end gears in an sn95 rear axle assembly. oh, and ill be using a T5 not an AOD. what should i be seeing on the dyno and what times should i expect on the 1/4 mile?
91sLXeeper is offline
Old 03-18-2011, 05:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
read:
https://mustangforums.com/forum/5-0l...bers-read.html
please do not violate this policy again, thank you
mjr46 is offline
Old 03-18-2011, 06:12 PM
302army187
302army187's Avatar
around 260 to the wheels, and low 13's high 12's if you can drive
302army187 is offline
Old 03-18-2011, 07:41 PM
87Stallion
87Stallion's Avatar
Hell up here that barely gets you a 14 sec car. I had a VERY similar setup and at 4000 ft above sea level I ran a best of 13.89 and mine made 270 RWHP
87Stallion is offline
Old 03-19-2011, 09:08 AM
holyshift
holyshift's Avatar
As stated close to 250-260ish,if you can drive it 12.90's 13.0's.
holyshift is offline
Old 03-19-2011, 03:01 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
13 flat, 250ish rwhp
sn95_331_GT_ yellow is offline
Old 03-20-2011, 07:32 PM
91sLXeeper
91sLXeeper's Avatar
I forgot to mention the heads are ported and polished, and ill have full length headers and an offroad xpipe full exhaust. also ill be using a 150 shot eventually
Old 03-21-2011, 04:03 PM
Tha Boss
Tha Boss's Avatar
The guys up top are pretty close. Maybe 265 to rear wheels. Low 13's on the time!
Tha Boss is offline
CS2007
06-25-2019 09:45 PM
b8checker
10-08-2015 12:55 PM
Explosive
10-02-2015 07:45 AM
b8checker
09-30-2015 07:11 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: What kind of HP can i expect?
