What intake gaskets for victor jr intake?
Ive been searching online but couldnt find the answer... I just bought a victor jr intake (carb) and need to know what intake gaskets to use because im about to place a order through summit. Thanks in advance for any help.
Summit says the fpp-1250's are not available, how about the fel-1250's? They have the same specs
http://www.summitracing.com/parts/FEL-1250/
printoseal gasket
fel pro #1250 are printoseal gaskets, they are pure garbage, don't buy one unless you want instant coolant and vacuum leaks, they are made out of vinyl rubber with no inner metal core and can't stand up to the normal heat of the engine and a everyday running car. They are used by racers who tear down the engines after every race. I wouldn't go a 1/4 mile with a printoseal gasket. The intake gasket you want is a victor reinz #95186sg they have 1.20"x 2.00" ports or #95107sg with 1.28"x 2.10" ports with metal core and graphite impregnated outer fiber nitro seal, depending on the port size you need. You can buy one at northern auto parts online. Avoid printoseal gaskets like the plague.
fel pro #1250 are printoseal gaskets, they are pure garbage, don't buy one unless you want instant coolant leaks, they are made out of vinyl rubber with no inner metal core. They are used by racers who tear down the engines after every race. I wouldn't go a 1/4 mile with a printoseal gasket. The intake gasket you want is a victor reinz #95186sg they have 1.20"x 2.00" ports with metal core and graphite impregnated outer fiber nitro seal. You can buy one at northern auto parts online
