5.0 rebuild
Old 05-11-2011, 11:49 PM
Vortech98
Vortech98's Avatar
Default 5.0 rebuild
Hello my name is jeff and im new to the site as well as rebuilds. I have a 302 block thats bored .030 over with stock crank, kb performance 12cc dished pistons, comp cams 31-226-3 cam kit (lifters, springs, timing set, cam) gt40p heads with stock valves, gt40 cobra intakes with stock tb and maf, running an intercooled vortech v1 charger at 10 psi. Does anyone know about how much power I will have and if my setup is ok. Thanks
Vortech98 is offline
Old 05-12-2011, 06:46 AM
uedlose
uedlose's Avatar
dont really know but I have a customer of mine that runs a set up close to yours. His car runs 7.00s in the 1/8 mile that's pretty darn fast for what it is. I would run a big T/B and Bigger Mass air also IMO.
uedlose is offline
Old 05-12-2011, 08:12 AM
Rat fink
Rat fink's Avatar
Probably 350 HP ish. The biggest improvement is not even at the motor, Some 4.10 gears will bring that colt to life. If your new to rebuilds, I'm guessing it wont even run for more than 5 min. But I have been wrong before. get someone who knows what there doing and ask them to help you.
Rat fink is offline
Old 05-12-2011, 11:52 AM
Vortech98
Vortech98's Avatar
I will eventually go with bigger tb and maf and as far as the gears ill def go that. Other than that will my setup be fine. What would I need to push over 400
Old 05-12-2011, 02:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
PLEASE READ AND DON'T VIOLATE THIS POLICY AGAIN, thank you :
https://mustangforums.com/forum/5-0l...bers-read.html
mjr46 is offline
Old 05-12-2011, 04:36 PM
nitrous_bob
nitrous_bob's Avatar
umm.... about a 150 or 200 shot
that 350 quote was about 100+ shy of what you'll have.
are the heads ported at all ? is the intake a cobra or explorer lower?, does the lower say BA or AA after the part number. BA is explorer and small ported, AA is cobra / real gt40
if it's explorer lower and unported heads you'll make just about 200-225 when it's back together
nitrous_bob is offline
Old 05-12-2011, 04:38 PM
nitrous_bob
oh i missed the blower... but i still dont see 300 at the wheels.
that motor will be choked out completely from the heads, intake, maf and TB
Old 05-12-2011, 04:41 PM
Venomantidote95
Venomantidote95's Avatar
Dont be discourage by ignorance thats the way to learn most anything!
your combo is a bit on the stockish side with a blower!
Is it intercooled? the T/B and MAf upgrade is really a must to get the most power from your setup!
case in point get a coffee straw and take a deep breath and blow really hard and thats close to what you are gonna be doing to your blower!
Why that cam choice???? do you have an older engine or what? If its a roller engine and you went reg hydraulic flats then you took a few steps back then.
Venomantidote95 is offline
Old 05-12-2011, 06:41 PM
uedlose
uedlose's Avatar
dont worry get the bigger T/B and mass air the heads will be just fine and the intake will work also Like I said my customer has nothing more then a 306 with a e-cam he does have a ported real Cobra intake 70mm T/B flat top pistons unported GT40ps shorty headers and full 2.5 exhaust with 42# injectors and a 95mm draw through mass air yes 95mm. C4 and 4000 stall 410 gears and a full weight hatch and all the accessory's runs 7.0?s all day long with 10 psi of intercooled boost at the intake. do the math ET weight of a hatch lx. it makes good HP and this is done with NO tune/Chip at all and stock timing on street gas. 7.00 in the 1/8 is low 11s to high 10s in the 1/4 so like I said the power with most of the parts you have will come to you. Have fun with it.
uedlose is offline
Old 05-12-2011, 08:26 PM
Venomantidote95
No doubt it will make decent even good power its a blower! it has no choice, if it dosent theres something definatly wrong!
Quick Reply: 5.0 rebuild
