CAN I ADD 2 COLD AIR INTAKES TO MY 88 MUSTANG?
i have an 88 mustang gt foxbody, i recently bought a cold air intake for it and installed it. it crossed my mind if i was possible to install another one. what do you think? i need some advice. what are the pros and cons to this situation ?
It would do absolutely nothing. Just clog up your engine bay, cost you money and do nothing for you. You would still be sucking in the same amount of air as one, instead it would be coming from two different sides, causing the airflow to be cut in half for each of them (assuming the set up is symmetrical, if not it would depend on the lengths of tubing and mass flows of the air)
Point it, it wouldn't do anything for you
Just because it CAN be done, dont mean it SHOULD be done. waste of time, money and engine space. It will do absolutely nothing for performance and make you engine bay have the appearance of a ricer
