Anyone got an R block
I might be picking up a nicely built 331 with r block, I believe the guy I'm buying it from but I've never seen one in real life to know what to look for. Anyone know what kinda HP they're good for? Any markings to look for from the outside?
We run one. it only has 2 freeze plugs down the sides stock has 3. front LT side of the block (driver side) has SVO cast into it maybe hard to see, it also has freeze plugs in the front of the block. The block will handle more HP then most can make.Seen people making well over 1500hp on them. 4 bolt mains on 3 caps and 2 bolt on the ends.
how much would you all think it's worth with the parts listed below
R302 Block, Bore & Hone, Line Hone, Blue Print Deck, Plug Deck 80, Notch for Stroke, Notch for Rod, O-Ring Block, 4340-3250 Stroke and Balance, Scat H-Beam Rods, JE Pistons 8.5 Compress, 1/16-1/16-3/16, 302 HT Mains, 302 HT Rod Bearings, Oil Rail Support, Comp Cams Camshaft, Billet Timing Chain, Rear Main Seal, 28oz Balance, Change Cam Bearings, Assemble Short Block, Aluminum Water Pump, Oil Pump, Crankshaft Damper, Head Stud Kit, Tappet Hydraulic Rol, 28oz Billet Flywheel.
