Return to the track after 2 years
#31
there is a local guy with a new 50 that has been smacking everyone in town right now well the average guys I should say. he smacked a 331 stroker over on 40 a couple weeks ago and then there was a 640 HP GTO at the cone zone last Fri. who got butt hurt when the Stang smacked him. Well someone is full of **** the Mustang my son seen it put down 444 HP at the tire it is tuned with long tubes and CAI and exhaust that is it and it runs 11.60 so they say I am starting to think he has a shot hid on the car LOL. With all the butt he has been kicking I mean there has been more also. things are getting very interesting later at night at the cone zone.
#32
#33
Maybe time for a EVAC system. I am putting one on our car this time valve cover to the exhaust somewhere. They say you cant run muffles with them but I have seen a good many turbo cars running mufflers with the kit so I bought the stuff to do it. if don't work you will know LOL. Maybe your stuff just has not sealed up yet did you hone the block any? What rings did you go with? I am kind of concerned about the same thing with ours sealing up with just a bead hone job and Hell fire rings. If it don't seal it wont be safe out my way for weeks and I am gone to sell the junk if I don't burn it first..
#34
#36
#38
That's good to hear. I will be trying them on mine gone to do one valve cove first then move to doing both if need be.
#39
#40
I use a header evac on my car with x pipe and a straight thru design muffler,ideally a vacuum pump is the better solution.Mj hose that thing with your current gear,might as well if its there,also I only run 93 in my car with timing locked at 34 with my box pulling 5 degrees at the hit and 5.75psi fuel pressure....results are below. Have talked extensively with the best in the business in N20 and fuel. Mixing fuels can cause false readings on spark plugs when spraying,not saying I disagree with mixing fuel,but if your trying to get a good read on a fresh set,it ain't gonna happen.
