wanting to know
Old 11-03-2013, 10:13 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
94 mph = not good....I was able to do 101-102 on a stock bottom end with stock e7 heads and a f-cam and just a edelbrock performer intake, I'd say some tweaking of your combo is needed
mjr46 is offline
Old 11-04-2013, 07:48 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Yep, at that weight and trap speed, there is something not right with your setup. If you punch those #'s in the chart, your a tick over stock power. About 200 at the wheels. How does your car run? Any issues at all?
88 orangepeel notch is offline
Old 11-04-2013, 08:54 AM
dawson1112
dawson1112's Avatar
Guy says he was spinning all through 1st and part of 2nd so that probly has a lot to do with the low trap speed.
dawson1112 is offline
Old 11-04-2013, 11:00 AM
88 orangepeel notch
Yeah that sure doesn't help, but even if you give him a 14.0 at 97, that's still around 210-215 at the wheels with his weight. And yeah, that is coming off that chart in the sticky, but it's dead on with my car ran and dyno'd. Those mods should be helping more than that.
We'll get that car in the 12's before we're done lol.
Old 11-05-2013, 12:26 AM
tinman
tinman's Avatar
Slide rule I use says 205HP.
Sounds like time for some tires, gears and suspension work.
Car could be 13.20's easy as I see it........
tinman is offline
Old 11-05-2013, 01:08 AM
bluebeastsrt
bluebeastsrt's Avatar
Spinning effects your sixty & ET. Trap speed usally isn't much different.
bluebeastsrt is offline
Old 11-05-2013, 08:53 AM
oREDNECKo
oREDNECKo's Avatar
3.55 gears upper and lower control arms are from upr and I just put brand new tire before I done and thing to the car it had a b cam in it and I could go 14.5 but I did have the 4banger trans in at that time to I just need practice at lunching I going to track again this Friday to see if I do better I going to mm et my buddy try a pass since he raced more than me
oREDNECKo is offline
Old 11-05-2013, 10:57 AM
88 orangepeel notch
Are you running street tires, drag radials or slicks? With those times and traction issues I'll assume they're just street tires. You really need to get something with more bite if you want better et's. Your 60ft is key to happiness.
Still doesn't explain the low trap speed with your mods thou. If your going back to the track this Fri. try different shift points, etc. You should be trapping much higher, that's if there is nothing wrong with your car.
What year mustang is this, and it would it be a convertible? A stock LX fox was capable of low 14's stock, some will say even 13's.
Old 11-05-2013, 05:57 PM
oREDNECKo
oREDNECKo's Avatar
Yes its a vert I have alot of stuff striped out I just going to shift at different rpms to see whats best no issues with car my timing is right on point what rmp should I be at when I launch couple people think they cann beat me but I have raced them at 20 mph roll and I kill them every time any help would be nice
Old 11-06-2013, 06:59 AM
88 orangepeel notch
Launch rpm will be determined by what tires you have, street tires (not drag radials) don't hook up well. You'll need good sticky tires to launch any harder than you are now. You know the saying "if your spinning, your not winning" is true. Let us know the outcome on Fri.
P.S. And some punctuation would be nice, replys as one big sentence are harder to understand lol.
Quick Reply: wanting to know
