Got it. '87 T-Top GT
Old 05-17-2014, 08:16 PM
  #21
2000AZ5.0GT
2000AZ5.0GT's Avatar
Originally Posted by 65Raven65
Wow!
It's amazing what a difference a quality, properly functioning part can make.
I put the new Accufab throttle body on today, and it fixed two problems. The throttle doesn't stick anymore, for one.
Also, on a hunch I thought that maybe the bucking and rough running when warm might be because of the EGR, so I got the Accufab EGR delete spacer. Now it starts up nice, runs smooth, and doesn't hesitate when I go to start it.
The car is actually a pleasure to drive now.
This is the one I got:
http://www.latemodelrestoration.com/...-Throttle-Body
Did you end up having to install a full EGR delete? I just got a new throttle body because mine was sticking as well, so I'm glad that it worked for you.
2000AZ5.0GT is offline
Old 05-17-2014, 10:01 PM
  #22
65Raven65
65Raven65's Avatar
Thanks. Yeah. The new Acccufab throttle body came with a "blank" spacer that completely deletes the EGR. It's basically just a chunk of aluminum that has a hole through the middle, and a place to bolt up the throttle cable.
It looks like this, but I got the 70mm. (and got it from Late Model Resto, the picture on their site is not accurate)
http://www.americanmuscle.com/accufa...acer-8693.html
65Raven65 is offline
Old 05-22-2014, 05:09 PM
  #23
65Raven65
65Raven65's Avatar
The car's 3rd brake light had the original dealership name on it. The name was embedded into the plastic so there was no way to get rid of it, so I found a replacement one on ebay.
If you've never had to replace one of these, they're hard to find. They don't repro these so finding a used one is your only option. Unfortunately the guys selling these know that, so they're proud of them.
Old 05-22-2014, 06:59 PM
  #24
bluebeastsrt
bluebeastsrt's Avatar
Looks like it's coming along nicely, All like to read someones build diary.
bluebeastsrt is offline
Old 05-23-2014, 01:35 PM
  #25
88 orangepeel notch
88 orangepeel notch's Avatar
Congrats on the progress, it is nice when new parts ( throttle body ) work better than anticipated.
88 orangepeel notch is offline
Old 05-25-2014, 10:35 AM
  #26
65Raven65
65Raven65's Avatar
Thanks guys.
I'm getting going on this thing quicker than I had originally planned. I really didn't want to dump too much money into it right from the start, but there's just things that I think it needs to get it to an enjoyable point.
I got my new headlights in, if I have time later today I'm going to put them on.
Old 05-25-2014, 06:07 PM
  #27
65Raven65
65Raven65's Avatar
I got the headlights installed today, but found that the drivers side adjusting plate is cracked and broken in two places, so that will need to be replaced.
Also, when I went to go pull the car back into the garage, the starter hung up and I had to pull the battery cable off real quick. It seems to be intermittent, but I'm going to replace the starter before it gets worse.
One step forward, two steps back. LOL
Old 05-26-2014, 03:05 AM
  #28
2000AZ5.0GT
You might check your ignition switch, I know you just replaced it, but if the electronic part got stuck, might cause a hang up as well, like if you held the key on too long.
I had the opposite issue, I had to rotate the key slightly backwards after starting to get the accessories to turn on, turned out be the electrical connection in the ignition switch, but it was a simple, non-mechanical fix, which might be a good place to start, idk
Old 05-26-2014, 10:48 AM
  #29
65Raven65
65Raven65's Avatar
Thanks, yeah, I thought about that. I hope it's not that though, it was a major pain to replace. (although this one probably wont have to be drilled out like the original one did)
The only reason I figured it was the starter or the solenoid, the same thing happened recently to me with my 4Runner. The starter stuck in the on position and I had to undo the battery real quick. (but it had been giving me warnings for over a month)
Old 05-26-2014, 08:03 PM
  #30
dawson1112
dawson1112's Avatar
Just had to replace the solenoid on mine a few weeks ago because of this, easy fix.
dawson1112 is offline
Quick Reply: Got it. '87 T-Top GT
