replace original fan with mishimoto 12in electric radiator fan
Old 06-26-2014, 07:24 AM
robotnix
robotnix's Avatar
Default replace original fan with mishimoto 12in electric radiator fan
Mishimoto 14 in. Performance Slim Electric Radiator Fan (79-14 All)
http://www.americanmuscle.com/mishim...iator-fan.html
has anyone tried this? for $85 I want to install this, it's slimer and it's electric but I wonder if anyone has tried it? does it work as well as the oem fan?any comments?
thanks.
robotnix is offline
Old 06-26-2014, 07:43 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Sorry, I don't have that fan. But can say this, when I replaced my stocker with an electric, there was a definite off idle power increase that you could feel. Not night and day, but worth the switch.
88 orangepeel notch is offline
Old 06-26-2014, 09:45 AM
robotnix
robotnix's Avatar
I want to do this for 2 reasons,
1- what you said
2- since it's a slim fan it will make room infront of the engine so I wont' have to take everything down every time I want to put my hands there
well 3- use my new 130 amp alt I put it there for a reason
robotnix is offline
Old 06-26-2014, 09:58 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
thanks.
We've had great reviews on this product. Mishimoto makes a great part and I think you'll really enjoy it. You're looking to install this item for the exact same reasons as I would and I don' think you'll be disappointed.
-Dan
AMDanBailer is offline
Old 06-26-2014, 10:02 AM
robotnix
robotnix's Avatar
ordered it
thanks.
robotnix is offline
Old 06-26-2014, 11:17 AM
bluebeastsrt
bluebeastsrt's Avatar
Ive read nothing but bad things about Mishimoto quality. Hope you get a good one.
bluebeastsrt is offline
Old 06-26-2014, 12:58 PM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Since you live in Quebec, probably won't be an issue, but the dual 12" fans that I just installed don't move nearly enough air with the A/C on, but at least with the one you linked to, there isn't a shroud to reduce air-flow when you're moving, so you might be okay
Also, depending on how many amps it draws, your stock alternator might not hold up at idle.
There's a lot of speculation[1] that the stock fan pulls about 2500-3000CFM, so if you assume even 1500CFM for the stock fan, you're going to be losing air with the MishiMoto.
I'm personally thinking about going with dual 12" Derale Performance fans[2], supposedly rated at 4,000CFM and only drawing 18amps
[1] http://forums.corral.net/forums/7065054-post8.html
[2] http://www.summitracing.com/parts/der-16830/overview
2000AZ5.0GT is offline
Old 06-26-2014, 06:15 PM
Maxwelhse
Maxwelhse's Avatar
Return it and buy a Mark 8 fan... Best E-fan on the market for a Fox. However, the fan motor DOES sit close to the water pump (mine is very close, in fact) and it requires some fabrication to install.
Maxwelhse is offline
Old 06-27-2014, 06:11 PM
robotnix
robotnix's Avatar
I'm going to give it a chance. here the hottest we get is like 104 or 40celsius and then again this happens only 1 time a year or maybe 2 times if we're very lucky yes I said if we're lucky
thanks all for your feedbacks.
robotnix is offline
Old 07-17-2014, 03:49 PM
5.0kid
5.0kid's Avatar
Set contour fan cooled the crap out of my engine when the stock clutch fan couldn't keep up anynore.
5.0kid is offline
Quick Reply: replace original fan with mishimoto 12in electric radiator fan
