What are you runnung for oil?
Haven't done an oil change yet, but I don't think you can go wrong with any top quality oil meeting Ford's specs. I've used Redline, Royal Purple and been using Mobil 1 in everything for years with no problems. Amsoil is typically rated one of, if not the top, synthetic oils, so I would not expect any issues with that brand either.
Also, as to change intervals...go with manufacturer's recommend to stay in warranty and document the changes with receipts for oil and filter.
After the warranty expires, I go 10K between changes (with synthetic oil).
Yeah, that's a decision you have to make for yourself. I feel that the better lubricity of a synthetic and longer change interval works for me. I kind of wonder if Amsoil is better than it really needs to be, if that makes sense.
While under warranty I would stick with the dealer for oil changes and use either semi-sythentic (minimum required) or full synthetic from motorcraft. With the dealership the records are kept and available when any type of warranty issue arises.
