5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
tach redlight at max rpm's
Old 10-25-2011, 11:56 AM
Napoleon85
Napoleon85's Avatar
Originally Posted by jimj3125
Was thinking of setting rev limiter to just above 6500. That is where the max horsepower is.
Will get out today and try it.
Wouldn't you want to set it a couple hundred RPM past where the max horsepower is? Why would you want to cut fuel at the point where you are making the most power?
Napoleon85 is offline
Old 10-25-2011, 02:05 PM
hawkeye18
hawkeye18's Avatar
It has been proven over and over and over and over again that shifting AT peak HP costs a lot of time and wastes a lot of power. It's not just what RPM you shift out of one gear at, it's what RPM you will enter the next gear at. That is why you go past peak RPM.
hawkeye18 is offline
Old 10-25-2011, 09:40 PM
JIM5.0
JIM5.0's Avatar
Actually, you never want to shift according to peak HP, you really want to shift in relation to when you are leaving the meat of your torque curve.
Max HP is almost always nothing more than an indication of how well your engine can produce decent torque at a high RPM.
And believe it or not, it is possible to get 500 HP from only 100ft-lbf torque. You just have to rev beyond all FUBAR of an RPM to do it.
Considering the torque curve's meat, you ideally want to rev your engine to the RPM where your torque curve is dropping and then shift such that the next gear puts your RPMs down to where you are beginning to enter the meat of your torque curve.
You can actually feel this effect when you know when to shift. The car pulls hard throughout all gears in a given run.
If your car is already dropping in torque at only 6500 RPM, your engine has something wrong with it. The Coyote holds onto its torque above 7500 pretty well as modders have proved by tuning ad moving the rev and fuel cut-off limits.
JIM5.0 is offline
Old 10-26-2011, 12:24 PM
jimj3125
jimj3125's Avatar
Smile
Well, ok then. Thank you all for the great info. Someone said you never stop learning and you guys proved it. What a great forum.
jimj3125 is offline
Old 10-30-2011, 09:45 AM
FastDEW
FastDEW's Avatar
2010 forward has this feature. It's not adjustable as far as I know
FastDEW is offline
Old 10-30-2011, 10:56 AM
EP2010
EP2010's Avatar
my 2010 does the same thing its kinda cool
EP2010 is offline
Old 11-02-2011, 01:41 AM
angryBits
angryBits's Avatar
Found it on mine by accident - was kinda shocking at first.
angryBits is offline
Old 11-02-2011, 04:01 PM
Jiggy_One
Jiggy_One's Avatar
One think you guys probably dont also know is that if any of your other gauges are showing trouble, like you are on E with gas or your temp gauge is in the red, then the whole gauge glows red like the tack does. Take your car to E on gas, way past the gas light and you will see it.
Jiggy_One is offline
Old 11-02-2011, 05:50 PM
Napoleon85
Napoleon85's Avatar
I'll take your word on that ... running out of gas is not fun.
Old 11-09-2011, 10:26 PM
JIM5.0
JIM5.0's Avatar
I agree. I too have run out of gas, even to the point that fumes were gone and the fuel rails were bled dry.
Restarting the car and turning and turning and turning the starter to prime the fuel rails again must not be a good thing for a number of reasons: the fuel pump running in a dry state, the injectors with a lot of air in it, etc.
JIM5.0 is offline
Quick Reply: tach redlight at max rpm's
