5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Ford Racing K Springs
Old 01-10-2012, 02:47 PM
Mikado463
Mikado463's Avatar
I'm in agreement with both Jim5.0 and John, when I installed my K springs a year ago it aligned A-OK, I did not put on an adj panhard bar (slightly shifted 3/16") but plan on installing a BMR this coming spring.
Mikado463 is offline
Old 01-10-2012, 05:06 PM
pascal
S197 Section Modder-ator
pascal's Avatar
The K springs are borderline to where you won't need CC plates...
But I installed a bunches of these and I found out that you DO need them more often than not.
So your shop dude just want to send you down the road as soon as he gets paid and let you find out on your own that you can't align the car properly once you notice uneven wear on your front tires.
I have a real cheap alternative to correct that problem but you might not like the idea, lol.
pascal is offline
Old 01-10-2012, 09:16 PM
kzonts
kzonts's Avatar
I thought camber bolts could potentially fail under certain conditions. Please correct me if I'm wrong.
kzonts is offline
Old 01-11-2012, 01:49 PM
stang8psi
stang8psi's Avatar
you do not need new mounts, you can just use the camber bolts..
cc plates are not needed as the camber bolts work just fine and will for years!
The mounts are ONLY needed if you are changing the dampers IE. koni str-t's, stedda, ford racing. The only reason the top mounts are changed is because there are no 2011 specific dampers out yet that don't require the use of new top mounts. All the dampers with the exception of eibach are 05-10 Mustang dampers and thus the need for the top mounts!
Camber can and will be in spec after the install of the camber bolts from eibach. ( Camber won't kill the life of the tires ) It's the toe that will give your tires the short life, Camber is to affect turn in handling!
Hope this helps some since you haven't gotten a dirrect answer to your questions!
stang8psi is offline
Old 01-11-2012, 07:19 PM
mattaglover
mattaglover's Avatar
ok thanks for all the help. Sounds like I just need some camber bolts and panhard. If the tow is out too much I will just buy the steeda upper strut mounts. They say 1 degree either way so that should work.
mattaglover is offline
Old 01-11-2012, 09:59 PM
stang8psi
stang8psi's Avatar
No you don't need them either.. toe can be adjusted with factory pieces. The only thing you need are the springs, adj panhard bar, and camber bolts. That's all you need for springs. Now if you were going to Do shocks and struts you would need the upper mounts, but if your not than just get the listed above items.
Old 01-16-2012, 09:08 PM
JIM5.0
JIM5.0's Avatar
I'm actually interested in knowing what this alternative is
JIM5.0 is offline
Old 01-17-2012, 08:03 PM
pascal
pascal's Avatar
OK...
Good ole carbide tip will get it done.
pascal is offline
JonnyBlazeGT
11-03-2015 01:10 AM
squishbang
Suspension
11-02-2015 03:42 PM
squishbang
09-07-2015 07:57 PM
Urambo Tauro
09-07-2015 12:47 PM
mustangfan305
08-07-2015 11:09 AM
Quick Reply: Ford Racing K Springs
