Ford Racing K Springs
I am being told by the shop I dont need anything but springs and panhard. They are telling me it stays within specs without cc plates or camber bolts. The old guy I have been talking with has done two of these cars so far. Im just not sure because I see some people say you need them and some say you dont. Why is that?
Just to be sure, I would get the camber and caster plates too. You never know to be honest.
Sure, most cars can get by without them, but when it comes to further suspension mods you might want to do down the line, the CC plates would then become indispensable.
If your shop guy says you will be okay without them, I say go ahead as he says so long as he guarantees his work and his claim.
And just in case he is wrong, you should make an agreement that he would correct the work and put on adjustable CC plates for free as part of the correction.
I used the Eibach Pro Align bolts. The car didn't need much and they worked out perfect to get it within the specs. I have a J&M Adj. Panhard bar on the way to get the rear end centered. Might wait to put that on until I get LCA's.
when i put my k springs in, and did the alinement at work, i used camber bolts from NAPA, and started with them all the way out. didnt need adjustment on the camber after that. i set my BMR panhard bar to the stock length, and i was only .5 degrees off center. so if i i were on a tight budget, i say the bolts are more important than the panhard bar. i heard that the upper mounts need to be replaced, but i havent had problems with them clicking or popping, and i autocross alittle, so thats up to you. enjoy.
