Another #8 Cylinder Issue?? Need HELP
#102
The front O2s have the ability to read A/F and communicate with the PCM to adjust A/F. That is in no way a failsafe replacement for not getting a tune when you install a cai or even headers IMO. Also you can have catastrophic problems if a front O2 extension becomes disconnected because it will automatically adjust the A/F ratio to 1 lamba which is too lean. That is why it is recommended not to use them.
#103
He's already admitted to everything he's done, planned to do or not to do, on this public forum. For his sake, I was hoping that he'd spill less information.
Hope he gets it figured out. A good non OEM rebuild isn't a "bad" thing though!
Ahhh..wow, ANOTHER thread that ends in a similar fashion. Either A an attorney got involved or B, the dealer/Ford said, if you want this taken care of stop posting. A couple of other threads have ended this way on other topics. Not this topic about Cyl #8 but other items.
Interesting...
Interesting...
#104
ok I am going to b the one and say it..OP this is a shady ending. is ford covering it? or is brenspeed? or did your claim get denied? I for one F*cking hate when these OP come and start threads and it all turns to "oh I can't say anymore" get the F*ck outa here.. People like you always do this on the forums and it never helps people or makes you look like your just another TROll that starts this sh*t on all the forums about the number 8 crap!
#106
Why not? I thought you were dealing with Ford not the FBI jeeezz....
#108
Your numbers look right for a boss. A stock Coyote GT makes the same or a tiny bit more torque than your Roadrunner. But your Roadrunner out revs a Coyote so you have more HP. A Coyote only gets about 375 or maybe 380 HP at the very best (and a tune is required to get that!)
#109
With the Aluminator, you can FI, nitrous, etc. and it is designed to take it.
#110
He has a CAI+tune, a lot of coyotes have dynoed at 405whp with just cai+tune..
Keep in mind though that every dyno reads differently, you can go back a week from now same dyno and dyno 10whp higher, or maybe it will be the same. or you go to a different dyno and get 10 lower or 20 higher.. they are just tuning tools. Don't put too much into what a dyno reads. The dragstrip will tell you more about your car than a dyno can.
edit: taken straight from another thread recently posted: 405rwhp and 387rtq from a cai+tune and cat-back exhaust (which adds little to no power) coyote.. and i've seen people report 427whp with the same mods I have, 415whp w/o the boss intake.
