Avic-f700bt help please
I got my Avic f700bt installed into my 2007 with the shaker 500. I forgot to tell him about the pop when the speakers came on so he said if i find a way to fix it he would. I decided to do it myself because im at college and it would be hard to get back just to let him do it. Anyways i put a voltage regulator the same one in the d-3 install sticky and it didnt work. My roommate is an electrical engineer and he help but it still doesnt work I dont know what to do any suggestions. I double checked everything and it all seemed right. The unit still works it just still pops. Any suggestions would be extremly appriciated. I am really frusturated. Thanks CJ
Is this the same kind of resistor that i just used http://www.radioshack.com/product/in...ductId=2062599 and do i need to take off the one that I already put on.
that is a voltage regulator and a little more complex way of doing the same job. The voltage regulator when hooked up right will keep 5v across the designated terminals. A resistor will burn the additional 6-7v off that is not needed and allow the amplifiers to see the 5v that they want. The resistor can't be hooked up wrong unlike the regulator is the biggest difference.
How do you protect the resistor, heat shrink? Will the resistor get warm?
PostRelease
11-11-2008 01:59 PM
PostRelease
11-11-2008 01:59 PM
PostRelease
08-13-2008 02:03 PM
