Project has been put on hold for the moment...
I picked up a new cd player to replace my factory Mach stereo system in my 2004 Convertible, however I have hit a roadblock at the moment. I believe that I blew a fuse, and can not find it, and both the new cd player and factory cd player do not work. I am replacing the factory head unit with a Pioner DEH-6200BT. I found out the numbers of the radio related fuseblocks however I do not want to start replacing the fuses unless I am absolutely positive on what they do for my Mustang.
when I suspect a fuse I do not even bother with the manual. STart in one corner and work your way across and it will take less time to phisically pull and check each fuse then it will to decipher the manual. Half the time the fuse that blows will have nothing listed like what you are looking for.
Don't forget the fuses by the battery.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
