Subs under rear seats with flat subs..Check this out!
Old 07-24-2011, 02:08 PM
lil_sixer
lil_sixer's Avatar
Default Subs under rear seats with flat subs..Check this out!
I thought this was interesting because I have always wanted to put subs in my car without taking up any trunk space so I ran across these flat subs that might fit under the rear seats. Check this ebay link out- http://cgi.ebay.com/PAIR-BOSS-NX10FD...ht_4201wt_1270
Is this brand pretty good and is anybody running the same setup?
Thanks!
lil_sixer is offline
Old 07-24-2011, 04:04 PM
pentavolvo
pentavolvo's Avatar
boss is pretty entry level stuff and IMO is garbage. There are other slims subs out there. IMO you have no where near enough room in a mustang to get subs in an enclosure under there
pentavolvo is offline
Old 07-24-2011, 04:43 PM
oldsch00lf00l
oldsch00lf00l's Avatar
I have yet to be impressed with the output of ANY shallow mount subwoofer! Thus far I've heard the offerings from Earthquake, Memphis, and Pioneer... I was left unimpressed!
Then again, I heard a JL Audio TW5 and it was better than the 8 and 10" shallow mounts I heard from the other brands. Stereo Integrity also had a decent shallow mount, the BM mkIII, but you'd have an easier time finding a unicorn than the SI sub.
oldsch00lf00l is offline
Old 07-25-2011, 07:56 AM
AudioNutz
AudioNutz's Avatar
Side panels?
AudioNutz is offline
Old 07-25-2011, 08:39 AM
d.girardi
d.girardi's Avatar
Kicker cvt
d.girardi is offline
Old 08-03-2011, 09:30 PM
Kpeters13
Kpeters13's Avatar
mtx has a good shallow mount sub. im also looking into shallow mount subs for my 89'. not quite sure where to put it though. how would the under rear seat mount work?
Kpeters13 is offline
Old 08-04-2011, 01:51 PM
AudioNutz
AudioNutz's Avatar
http://home.comcast.net/~bill.lawren...g/Mustang.html
Page 3.
Old 08-08-2011, 01:18 AM
ttocs
ttocs's Avatar
You will have a hard, make that a very hard time gettin ANY subwoofer under the rear seat as it is made to hold nothing more then spare change and old french fries. Now I mounted some audio componants under the front seats that were only about 2 inches tall and only needed to add 2 washers to raise the seat up enoug to clear them. So if you can get a flat sub that is less then one inch thick, and use 1/4" wood for the enclosure you should have no problem fitting them and getting them to slam if you hit a wall fast enough.
ttocs is offline
Old 08-16-2011, 11:43 PM
Shaft
Shaft's Avatar
Originally Posted by AudioNutz
I want to do something like that to my 93. Either that, or a JL Audio 13TW5 in the spare tire well.
Shaft is offline
Old 09-17-2013, 04:06 PM
gpwaltmi
gpwaltmi's Avatar
Default Need some bass as well
Got a 2007 vert. Added Fosgate in rear and still not happy with bass. Stock radio. No shaker. Would like to put custom mini-woofers in rear panel. Should be kicking. But who can do it? No room in trunk on a vert.
gpwaltmi is offline
Quick Reply: Subs under rear seats with flat subs..Check this out!
