Bullitt Mustangs
bullittproof01.....
Old 06-02-2007, 10:28 PM
Donnie's GTS
Donnie's GTS's Avatar
Default bullittproof01.....
Can you post some side shots of your car, I want to see what the sport lines look like.
Donnie's GTS is offline
Old 06-03-2007, 04:35 PM
bullittproof01
bullittproof01's Avatar
Default RE: bullittproof01.....
these are the most recent pictures of my car
bullittproof01 is offline
Old 07-13-2007, 02:38 PM
bullittproof01
ORIGINAL: BullittJim
did u ever look at those pictures? post some pictures of your car with the new suspension
Old 07-13-2007, 05:52 PM
Donnie's GTS
I will, when I do it, I'm either thinkin prolines or sportlines, my x pipe already scrapes freakin speed bumps with the stock, so idk yet.
Old 07-14-2007, 12:41 PM
5speedstang
5speedstang's Avatar
with your mid pipe jim when you put it on did you jack it up and then tighten it? i had the same problem i didnt know you were supposed to do that and i have no ground clearance issues anymore. loosen the bolts take a jack to the middle and jack it up all the way. than tighten all the bolts down and lower the jack and you will be fine.
5speedstang is offline
Old 07-14-2007, 02:59 PM
Donnie's GTS
Will that help bring the cats upwards as well, its the front two down tubes that make it go low I think.
Old 07-15-2007, 12:17 PM
wgdt21
wgdt21's Avatar
i have sportlines and i scrape a lottt.
wgdt21 is offline
Old 07-15-2007, 01:12 PM
5speedstang
i scrape once and a while but not alot. i was told these springs were the pro kit but im starting to think they are the sportlines
Old 09-28-2007, 09:45 PM
bullittproof01
dayum.... sittin low
looks great
