help ID which fuse I need for replacement on a 1966
Hello,
I have a 66 mustang convertible....pretty much stock...with ac.....289 v8
I was hoping you could help me ID what fuse I need for the "2.5 instal lt." on the pannel? My old fuse (maybe the original?) has labeled 32V on one end and uss aga 2 1/2.
Outside of the 32V, not sure what else I need to id this for replacement.....think they go by different labels now....I know it's a short fuse but I broke the glass getting the old one out. There are a few that would fit in there though....
what should I look for to fill that spot.
These two lights are not functioning...
the center console light (that shines at the feet of the backseat - below the coin box-
and the glove box light.
I got some new bulbs to try out but still does not seem to work. did a test light check on the fuse box and everything worked fine until I got to the 2.5 install lt. which did not light up. Is that the one that regulates those two interior lights mentioned above?
Thanks,
M
Thanks,
M
