What are you working on?
#7624
Yep, wheat harvest is wrapped up, but lots of follow up work right now. Saturday was the first full day off since about June 15th. Even played in an eighteen hole golf tournament and went to work after.
#7627
Location: Thomasville, NC Where we beat headers into submission!!
Been busy working on this stupid truck. I'm just lost at this point.
Idles rough as hell when it's cold, better once it warms up but it still lopes. Thinking maybe it's a bad lifter or something. Might try replacing the upstream O2 sensor and see if that changes anything.
in the last month I have replaced.
PCM
Crank POS sensor
Cam POS Sensor
Plugs
Cap / Rotor
IAC
TPS
PCV valve
and gutted the cat
Been working on compiling a mod list on the car for when I list it for sale. (don't worry Steve, you're center caps aren't going with it)
PCM
Crank POS sensor
Cam POS Sensor
Plugs
Cap / Rotor
IAC
TPS
PCV valve
and gutted the cat
#7630
Checked for VAC leaks yesterday with the ol' carb cleaner. found none.
No MAF on this one. It has a MAP sensor on the Throttle body.
Maybe a grounding issue. I looked at them and didn't see any signs of corrosion.
