View Poll Results: Which Wheels
Vintage Wheels V40
13
50.00%
Vintage Wheels V50
7.69%
AR Torq Thrust Original
7.69%
AR Torq Thrust D
34.62%
Voters: 26. You may not vote on this poll
Pick my new wheels, please
I'm cursed with being indecisive. I can't pick which new wheel I want to put on my car. Its a 67 C code that is candy apple red and down the road may end up a darker blue but that is far down the road. I am looking for an aluminum wheel, I don't want chrome. 15x7 225 60 15 or 16x7 225 50 16. This is my list that I am picking from right now, suggestions are welcome.
I am really looking for machined aluminum. If you can find some others please suggest
Vintage Wheel Works V40
http://www.newstalgiawheel.com/wheel...ubcat3=1111100
Vintage Wheel Works V50
http://www.newstalgiawheel.com/wheel...ubcat3=1111103
http://www.newstalgiawheel.com/wheel...ubcat3=1011104
AR Torq Thrust D
http://www.newstalgiawheel.com/wheel...ubcat3=1011100
AR Torq Thrust D
Just a quick question also, is there a point to go over 7 inch wide wheels in the rear on a 289 that will be mildly modified, nothing radical, just a H/C/I job or should I consider 8's in the rear? Or would I just be throwing away the ability to rotate my tires?
Good Q about 7" vs 8". Can the performance difference be appreciated on a street car or is it just cosmetic? Hmmmm...
If you get a matching set of 4 wheels the same size, they will be easier to sell if you wnat to change them in the future.
I voted for the Torque Ds because they are the coolest.
CP
After some research, it seems that you can rotate modern tires laterally, if they are kevlar and not rigid steel belts that will puncture the sidewall if rotation is reversed. Check with the manufacturer of the tires you plan to use/buy re: rotation, if that makes a dif in your wheel purchase. Most wear will be in the front, anyway.
CP
CP
8's all around wouldn't be a bad idea, according to Dodgestangs chart I can put them on with 225 - 245 without a problem. I was just wondering if 8" are overkill or if it really matters between 7" and 8" widths.
