how to wire parking lights to stay on with headlights?
Your parking lights are your turn signals also, right? I know this is why they are on at first pull and go off when the headlights go on on my '67.
You would have to find a way to interrupt the constant on signal when the TS switch is activated otherwise you'll loose your blinkers. It'll probably screw with the rear TS working also as even a burnt front bulb slows them down or stops them.
Jon
Jon
There are separate filaments for the blinkers.
I would not jumper the parking lights to the headlights because it will cause the headlights to come on when the light switch is in the parking light position.
What I would do is to find the wire feeding the rear tail lights and reconnect the front parking light wire to it under the dash. The rear tail lights, the dash lights and the license plate lights come on with the light switch in the park light position as well as the headlight position. And that's what you want for the parking lights.
Here is a '65 wiring schematic: http://www.hammar.dyndns.org/wiring/1965/1965e.jpg
Pictorial: http://www.hammar.dyndns.org/wiring/1965/1965d.jpg
The taillight wire is #14 (blk) and the front parking light wire is #11 (blk-yel). You could disconnect wire #11 from the light switch and reconnect wire #11 to wire #14. Or you could probably just put a jumper between wire #11 and wire #14.
I have always wanted to do this to my 65. never found out exactly how to do it, a couple of months ago while searching for efi swap I found a guy who did this to his 66. don;t know if it will mess with the turn signals, don't think so since the "original gt" had them one with the headlights. Let me search for the pic I saved and Ill post it up, I remember form the top of my head that you cold move a wire. Or you could install a diode. I'll post it later since I gotta go runs some errans.
Thanks guys great info
If I do not know how to solder wires and it would be a tight spot to do so near the headlight switch can I splice a connection using wire crimps?
Does anyone know what those snap splices are called like are on the headlight pigtail? That would work wouldnt it?
I always wanted to do this as well, but figured I would have issues from doing so. Now I can't decide. Has anyone else done this?
What was the reason they didn't light up with the headlights from the factory? Was it because of the low output alternators?
Ford wanted to introduce the sequential blinkers in the '64 model, but had to delay the feature until the '65 model due to a couple state laws that needed changing. Also there was a similar deal with using the 4 headlights that started in '58.
