I want to install '86 302 and 5 spd in '66 Coupe
Old 03-25-2010, 09:09 PM
Bob-Morton
Bob-Morton's Avatar
Default I want to install '86 302 and 5 spd in '66 Coupe
Hey everyone, New guy here. I want to install an '86 HO 302 with 5 speed into my '66 coupe. Any problems with shifter location or clutch? I'd like to not make any permenant alterations to the car. Might have to install a clutch master cylinder? Any thoughts greatly appreciated.
Bob-Morton is offline
Old 03-25-2010, 09:39 PM
71Mach14spd
71Mach14spd's Avatar
It depends on if you want to use a cable clutch or not. I'm assuming your car was a standard originally so you wont have to install a new set of pedals.
71Mach14spd is offline
Old 03-25-2010, 09:53 PM
Bob-Morton
Bob-Morton's Avatar
The car is an auto. I'll need to install a clutch pedel. Also, I plan to remove the enine's FI and use a 4 bbl carburetor. Did the 86 use a cable clutch?
Old 03-25-2010, 11:55 PM
GT350R Klone
GT350R Klone's Avatar
Hey Bob,
I'm new too, but welcome. The T5 conversion is one of the best swaps and lots of parts are made to do it well.
The 86 did use a cable. I've purchased parts from these guys in the the link below in the past and have never been disatisfied. They have 43 different parts for the conversion.
http://www.mustangsplus.com/xcart/T-5-Conversion/
Installing the 5.0 will also take some work and is pretty well documented on the web. You will need to change the oil pan, move the dip stick and decide if you are going to keep the serpentine belt. The water pump exits the other side...so few things to think about, but not big barriers.
GT350R Klone is offline
Old 03-26-2010, 02:28 AM
71Mach14spd
Well if you wnt to make as few mods to the car as possible then I would suggest going with an AOD conversion instead. It's the same thing as a t5 just the automatic equilivant. The only mods that you will have to make are to shorten your driveshaft and get a new crossmember or modify your original to fit.
Old 03-26-2010, 01:58 PM
tx65coupe
tx65coupe's Avatar
Take a look at Modern Driveline. They have info and parts for the T5 conversion. You will need a different crossmember. I am running their clutch cable, and I am happy with it.
tx65coupe is offline
Old 03-26-2010, 03:32 PM
Bob-Morton
Bob-Morton's Avatar
Thank you very much for all of your help. I've checked out the sites you've recomended and it looks like I'll have no trouble with the conversion. I'm sure I'll have about twice more in the car than it will ever be worth, but isn't that why we work on cars???
Old 03-26-2010, 05:18 PM
JamesW
Moderator
JamesW's Avatar
If you're a do it yourselfer..take a look at my website for some ideas
JamesW is offline
Old 03-27-2010, 06:08 PM
nba1341
nba1341's Avatar
Swap the heads out with some gt40s beforehand since the 86 heads suck
nba1341 is offline
Old 03-29-2010, 05:29 PM
tx65coupe
tx65coupe's Avatar
You can also look at Mustang Steve and Ron Morris for conversion related parts.
Granatelli Sales
01-20-2020 12:34 AM
TimeLord101
09-04-2015 09:27 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: I want to install '86 302 and 5 spd in '66 Coupe
